Vibration -Rotors and /or Ball Joint?
Old Oct 26, 2012 | 11:50 AM
rodmGluv's Avatar
Having a hard time diagnosing a problem with vibration. When i brake, i get the usual vibration in the pedal thats associated with warped rotors, but there is also movement i feel up through the shifter. Theres also some intermitent vibration not associated with braking from the front. There is no noise, just irritating, noticable vibration. All the shocks feel good and stiff. I'm thinking it may be a bad ball joint. Going to jack it up, pull wheels, and do a physical inspection of suspension components. Anyone have some ideas or experience anything similar. I don't want to overlook anything. Thanks.
Old Oct 26, 2012 | 01:35 PM
geew1z's Avatar
GL. I just ended a 14 month search for clunking noises and one problem was the inside bushing on the transverse link, the more annoying rattle ended up being the compression rod ball joint. After that experience, I would say if it was a ball joint, it would be a loud clunking annoying as hell sound over bumps.
That said, my front brakes are fairly crappy and do pulsate. I know that sometimes I have my hand on the shifter and it seems to move with the pulsing, but if I take my hand off it stops.. So it is just my arm moving with the pulses vs moving with the car.. if that makes any sense.
Old Oct 26, 2012 | 02:21 PM
sh0rtys463's Avatar
I had severe vibrations when braking and it was because my bushings were so bad (lower arm and compression rod), once I replaced them the vibrations were gone.
Old Oct 26, 2012 | 02:49 PM
onevoice's Avatar
How much did it cost to replace the two? Parts + labor?
Old Oct 26, 2012 | 03:23 PM
sh0rtys463's Avatar
I bought whiteline bushings and did the labor myself.
Old Oct 26, 2012 | 03:39 PM
VMRWheels's Avatar
It sounds like your brakes to me, but definitely check out the bushings!
Old Oct 27, 2012 | 08:54 AM
rodmGluv's Avatar
I definately think the brakes are contributing facter, but there is definately something else there. Bushings sound like a possibility. It is a 2004 with 118,000 miles on it.
Old Oct 27, 2012 | 02:34 PM
sh0rtys463's Avatar
Yeah you definitely could have warped rotors as well.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AL8782
Oct 3, 2015 10:26 AM
Jeff T
Sep 30, 2015 02:00 PM
