Rim lip hitting fender ,HELP !
Old Nov 14, 2012 | 04:43 AM
4drSS_V35's Avatar
For u aggresive stanced guys, I need help and opinions with my lip hitting my fender. How do u prevent this ? Im currently less than an inch from my lip to fender but only hits when its fully compressed like when im going in a angle in and out of drive ways. im currently running 19x11 +25 with -4.2 of camber and stiffened up my dampner almost to the max. my last resort but if i have to is to raise the rears a bit unless theres another way around this. Comments and opinions please.
Old Nov 14, 2012 | 06:49 AM
Shanes_G's Avatar
Your gonnna have to raise it or order like 30k springs from swift
Old Nov 14, 2012 | 08:44 AM
TGMcCoy's Avatar
is that how close your wheel to fender is on flat ground?
For stock stance gr+, does that valving of the struts need to be adjusted to use stiffer springs?
Old Nov 14, 2012 | 08:51 AM
Shanes_G's Avatar
To be honest I couldn't tell you that. I'm pretty sure it's a direct swap
Old Nov 14, 2012 | 10:40 AM
yosip1115's Avatar
MOAR CAMBAR. aha no. Get the fenders rolled out. It looks sweet too.
Old Nov 14, 2012 | 01:26 PM
VMRWheels's Avatar
Pull your fenders out more and/or get stiffer springs.
Old Nov 15, 2012 | 09:56 AM
TGMcCoy's Avatar
+1
Also: let's see some full pics of your car!
Old Nov 15, 2012 | 12:28 PM
4drSS_V35's Avatar
ill post pixels sometime today. but thats how it was the first time i slapped on the wheels and it looked sexy but lip kept hitting fender so now its raised up to were u can see all the words on the tire but still tuck a bit
Old Nov 15, 2012 | 02:44 PM
04nismoG's Avatar
The best way is to just roll your fenders pretty much everyone does it. It shouldn't cost no more than about $40-$60 per side and you'll be fine.
Old Nov 15, 2012 | 04:24 PM
TGMcCoy's Avatar
I'm pretty sure he already did for the tire not to hit the fender in that pic. He needs some more
Old Nov 15, 2012 | 05:48 PM
VMRWheels's Avatar
+1
Needs a pull to clear the rim of the wheel.
Old Nov 17, 2012 | 05:23 AM
4drSS_V35's Avatar
thanks for everyones input. fenders has been flattened and rolled but in order for me to pull that off i have to run another degree or 2 of camber and pull fender but i dont really want to lose the body line. i have it raised up but i missed how it looked slammed cuz it was so sexy. but again these are my new daily wheels so i cant afford to buy tires every other month Wich would cost me $800 a set and thats not even installed yet. thats y im leaning more into bags so i can achieve more. will have pix up soon.
Old Nov 17, 2012 | 06:22 AM
TGMcCoy's Avatar
In for pics
As for tires, if you are on the mainland, get cheapie Achilles / only about $100/tire plus shipping @
tires-easy.com. No reason to spend so much on cambered tires.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
jjohns2711
Aug 5, 2015 08:58 AM
EasySausage
Jul 14, 2015 11:17 PM
