Oil pressure light comes on when I turn
Old Nov 18, 2012 | 08:24 PM
WiestATV's Avatar
Unhappy Oil pressure light comes on when I turn
I tried searching for this but couldn't find anything on my specific situation.
When I make just a left turn my oil pressure lights comes on and when I straighten back out the light goes off. It also comes on when I make a sudden stop and then goes away. I'm really confused on what it could be, Please help!!!
Old Nov 18, 2012 | 08:42 PM
3truman's Avatar
Check your oil level.... i bet its low!
Old Nov 18, 2012 | 08:45 PM
WiestATV's Avatar
lol believe me that the first thing i did and its perfectly fine.
Old Nov 18, 2012 | 08:49 PM
3truman's Avatar
I had the same problem you described and my oil was low, not sure what else to check...
Old Nov 18, 2012 | 08:50 PM
JaE35's Avatar
Moderator
G35 Sedan
our dipsticks suck, change your oil and watch the light go away
Old Nov 18, 2012 | 09:23 PM
lilindienplaya's Avatar
just add about 1/4 qt of oil and see if the light goes away. Over filling it by 1/4-1/2 quart wont do any harm.
Old Nov 19, 2012 | 11:39 AM
P10 WRC's Avatar
def low on oil man. just get an oil change and you will be fine. be careful not to damage your motor though running oil low
Old Nov 19, 2012 | 01:26 PM
Mustang5L5's Avatar
Agree. Don't trust the dipstick just yet. Do an oil change and see how much comes out of the pan.
If you really want to check the dipstick, don't do it with a warm engine or immediately after driving. What i do is park the car on a level surface, then pull the stick and wipe it but don't put it back in all the way. Let the car sit a couple hours and then push the stick all the way in and check the level.
Old Nov 19, 2012 | 01:41 PM
Jaygotboost's Avatar
Low oil.. Yup
Old Nov 20, 2012 | 01:15 PM
TunerMax's Avatar
G35
There's really only 2 options and the 2nd one is unlikely
1. Oil issue (low, low pressure, etc)
2. Wiring to the Oil Pressure sensor is rubbing when you turn and shorting out
Old Nov 20, 2012 | 02:33 PM
VMRWheels's Avatar
Sounds like you're low on oil to me too.
RA102223
Aug 15, 2015 09:24 PM
ghost_g35
Aug 7, 2015 10:31 AM
TWASkyliner
Aug 1, 2015 11:43 AM
Luisgalvan33
Jul 28, 2015 05:37 PM
ClwMike
Jul 23, 2015 12:55 PM
