A/C Slushing Noise
Old Nov 19, 2012 | 09:18 PM
smartin0924's Avatar
Slushing Noise Behind Dash
I have a 2006 G35 sedan and lately I have been hearing a slushing noise behind the dash. I'm pretty sure its coming from the A/C not draining correctly. I found the drain tube on the passenger side and blew air into the hose; it didn't seem clogged. Has anyone come across a similar issue? I really do not want to take my dash apart.
Thanks for anything you can offer.
Old Nov 20, 2012 | 12:11 AM
Gsedan_760's Avatar
Your A/C system will make that type of noise when your freon level is low. Check for visible leaks from your A/C system. The most common places for it to leak out is from your A/C condensor and your A/C clutch seal on the compressor itself. Sonner or later your vents will only blow out only warm air.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
