Strut tower rust
Old Nov 25, 2012 | 07:54 PM
bh94's Avatar
Strut tower rust
Any advice on what to do here?
Just purchased an 06 sedan with 78k miles and missed this when I was looking the car over at the dealer.
There is a sticky gel residue on it (I cleaned that off) which I assume is what caused the rust to start. The top layer actually seems to be raised up a little from the rust where the passenger side (with no rust) lays flat.
Attached Thumbnails Strut tower rust-20121125_193404.jpg   Strut tower rust-20121125_193423.jpg
Old Nov 25, 2012 | 08:07 PM
PAIXAO's Avatar
Spray some rust converter on it or sand it and apply white primer over the area.
Old Nov 25, 2012 | 10:46 PM
AARONHL's Avatar
At least gray primer?? Haha
Old Nov 26, 2012 | 04:48 AM
5150DS's Avatar
+1 on rust converter. It should stop the rest and keep future rust from forming.
Old Nov 26, 2012 | 02:50 PM
VMRWheels's Avatar
+1 for Rust converter and primer.
Old Mar 20, 2013 | 03:25 PM
2005G35xSedan's Avatar
I have this same issue just curious on what you have done to address the matter.
Old Mar 21, 2013 | 01:48 AM
xsl_will's Avatar
I had a similar issue but caught it at a much earlier stage, as the others have suggested, use a rust converter such as POR15.
Old Mar 21, 2013 | 08:40 AM
Don't most rust converters turn to black so how did you address that?
Did you leave it black or how did you handle that?
I have white under my hood, black wouldn't be a good look.
I brought it to a body shop he said it's not worth the repair he doesn't see it being a problem but it looks horrible and would like to fix it if possible.
Old Mar 21, 2013 | 10:41 AM
G2B35AGN's Avatar
This would appear to be a somewhat common issue.I saw it on three G35s as I was shopping for mine; one of them was pretty extensive, the others more cosmetic. I think you are wise to try to find the early cure. The extensively corroded one was pretty ugly; if you let it go, it's likely to end up unhappily.
Old Mar 21, 2013 | 11:25 AM
Yeah I want to address the issue now because I want to start engine dress up and thats not a good look with rust around my strut tower.
I know there are products like rust converter, but they using change the color to black.
Which worries me because my car is white.
Old Mar 21, 2013 | 01:12 PM
xsl_will's Avatar
So paint it white over the rust converter.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
prinny
Nov 22, 2015 11:07 PM
Visionnn
Oct 3, 2015 05:16 AM
Claudiu
Sep 26, 2015 01:04 PM
