Where to place jack stands
Old Dec 5, 2012 | 12:03 PM
adwizard's Avatar
Hi. 2004 G35x sedan. I know how to use the jack that came with my car and the jack points for raising the sides, front and rear. My question is, where do I place the safety jack stand once my car is up in the air? It's a little bit perplexing to me. I have a pair of jack stands (see url of pic) that have somewhat of straight and wide flair at the top. Not a little slit like the car jack has. Where can I safely put my safety jack under my car without experiencing any unsettling surprises? I know this has been discussed before, but please look at the pic of my jack stand. Maybe I have one that just won't work safely with a G35. I appreciate your input.
http://www.flickr.com/photos/57301604@N04/8246772297/
Old Dec 5, 2012 | 12:07 PM
Mustang5L5's Avatar
Up front, i put mine on the cradle where the lower control arms bolt to the frame right next to the removable skid panel. There's a nice flat zone that's solid enough to put a jackstand.
Out back, i put them under the control arms, but that's a little sketchy. Fortunately, most of the time when i do oil changes, trans flushes, belts, etc...i'm working up front only. I chock the rear wheels and jack the front up high and put the stands where i described.
If you are using the OEM jack to do maintainence onthe car, id recommend a hydraulic jack instead. They are cheap and much safer and easier to use
Old Dec 5, 2012 | 12:48 PM
Deepdiver's Avatar
https://g35driver.com/forums/v36-gen...placement.html
Old Dec 5, 2012 | 12:51 PM
ccc123pm's Avatar
X
Old Dec 5, 2012 | 02:36 PM
VMRWheels's Avatar
Old Dec 5, 2012 | 04:46 PM
KingoftheRoad1's Avatar
One should not put the jack stand under ANY supension components!
Old Dec 5, 2012 | 09:16 PM
Mide's Avatar
I put them on the inside of the pinch weld area. If you look below near the pinch weld there is an elevated area near all 4 pinch welds. I put the jack stands the long way parallel to the car. That's me...
Jeff T
Sep 30, 2015 02:00 PM
Hogbone
Sep 28, 2015 06:44 PM
toadfire
Sep 21, 2015 07:15 AM
