Give a gal a break....coolant question....
I've searched and I know it's on here somewhere but just can't locate it - I have a 2003 G35 - suggestions/recommendations for engine coolant? I ran out for a quick lunch errand and my car heated fine while accelerating; however, when sitting in traffic, it's blowing cold air.
It's 39 degrees...I don't want cold air! Ha! Heading to Advance Auto when I get off work and I hate dealing with those bubbas so I'd rather have a little info on-hand before gracing their doors. Thanks guys!!
Ha! Sorry....what's the correct coolant for my G35? I really don't want to rely on the guy in the parts store to give me the right thing.
Any quality 50/50 coolant mix will work fine. I'm sure there are those who will say only OEM coolant, but I have not had any issues. As far as your heater not working, it may be the heater core.
http://www.infinitipartsusa.com/Item...984-117986.htm
I'd say this covered it.
Sounds more like you need to bleed your system, but if the coolant is low and good 50/50 will work just make sure to used distilled water (keeps mineral deposits from forming inside the cooling system)
Bleeder screw is on left side of the engine, it's a plastic screw on a hard pipe that I believe is going into the firewall. It's a bit hard to spot and explain, someone please help me explain the location better.
so should I help you again or are you just going to overlook this information as well.
http://crackaddict.com/~flynn/howtos...amco.howto.htm
Hey gurl, get the car warmed up to where the needle is in the middle with heat on full blast, then step on gas an hold it on 3-4k for 10 seconds...run around to the bleeding screw and unscrew it with a wide fat flat head screw turning slowly until air bubbles stop and cooling leaks out. You don't need to unscrew it much and then repeat that process like 5 times to see if the heat gets hotter. If it doesn't get hotter you have a leak and I would say that radiator is shot
thechitoguy
Oct 1, 2015 05:25 PM
