Cold Startup *squeak*squeak*squeak*squeak* - Belt noise?
Old Jan 15, 2013 | 11:19 PM
5150DS's Avatar
Z1 sells an idlers pulley delete with new belts for less than $50. This only applies if you have electric fans.
Old Jan 17, 2013 | 01:15 PM
g35indafuture's Avatar
Do you have the part number for the OEM Ac belt? Is the ac belt called a serpentine belt? I had my drive belts replaced a month ago and the squeaking is appearing again because of the recent cold weather in cali.
Old Jan 20, 2013 | 08:09 AM
achillesg's Avatar
Replaced my belts yesterday and the noise pretty much went away, made two separate errands, no noise. Then the car sat for a couple hours, started it up and *SQUUEEEAAAAKK* then nothing. Now whenever I accelerate from a stop with the AC on, it squeaks like hell. What did I do to cause this? Need to tighten up the belts some?
The pulleys all seemed pretty good when I had the belts off so I didn't bother replacing them.
Old Jan 20, 2013 | 11:12 AM
5150DS's Avatar
Tighten the belt with the ac.
Old Jan 23, 2013 | 11:45 AM
achillesg's Avatar
Tightened up both on Sunday and the noise is gone! Thanks for the tips guys, I'll post again if the noise comes back.
I ended up just changing both belts, not the pulleys.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
