Purchasing Control Arms (need help PLEASE) 03 Sedan
Old Dec 27, 2012 | 03:28 PM
sogirlish's Avatar
First off hello everyone! :-)
Im purchasing brand new control arms for my 03 sedan. The front upper control arms were easy enough to order...I also ordered the lower control arms for the front & passenger side BUT while ordering the parts I also see control arms for front lower driver & passenger side REARWARD control arm but the fit says COUPE. Does the sedan need these 2 parts as well? I dont know much about cars so any help would be greatly appreciated. Thanks
Old Dec 27, 2012 | 03:32 PM
JaE35's Avatar
Moderator
G35 Sedan
they are the same
Old Dec 27, 2012 | 03:43 PM
sogirlish's Avatar
Originally Posted by JaE35
they are the same
When you say they are the same, does that mean I need to purchase those parts as well to completely replace the front end control arms? Btw..thank you for responding.
Old Dec 27, 2012 | 03:50 PM
JaE35's Avatar
Moderator
G35 Sedan
It's rare you need to replace a control arm..especially the front ones since 95% of the bushings in them are replaceable. You don't need to worry about replacing anything other than the front upper and lower...not sure what else you're referring to.
Old Dec 27, 2012 | 03:53 PM
sogirlish's Avatar
Alright thank you. I learned after reading through some post in here that the bushings are replaceable.....after I already purchased the arms, go figure, lol. Again thank you for your help!
Old Dec 27, 2012 | 05:25 PM
totopo's Avatar
The front suspension on the g35 is actually technically a multilink, since there are 2 different lower control arms, for anti-dive purposes. I am not sure if the coupe and sedan have different parts, but there are definitely 2 lower control arms.
http://www.infinitipartsusa.com/2003...tm?searching=Y
Old Dec 27, 2012 | 05:27 PM
sogirlish's Avatar
Thank you Totopo!!
rezendvous420
May 31, 2020 01:26 PM
Jussaku
Jul 29, 2015 11:45 AM
teamghost
Jul 28, 2015 04:52 PM
itschuckster
Jul 25, 2015 08:07 AM
