G35 stalls after warm start.
Old Feb 19, 2014 | 11:51 PM
PongSanity's Avatar
From: Virgin Islands .. Your vacation is my home...
LOL... I realize I never replied to this thread but it was the camshaft sensor which is located on the passenger side of the engine. Fairly easy DIY... Bought the replacement off of Rock Auto.
Old Feb 20, 2014 | 12:43 AM
Fire0nic3's Avatar
Did you have any lights or codes on to know it was the camshaft sensors?
Old Feb 20, 2014 | 09:40 PM
PongSanity's Avatar
P0340 been the code
Ses, vdc, and slip lights been on.
Old Feb 20, 2014 | 09:51 PM
Urbanengineer's Avatar
Thanks OP You really shouldn't drive on bad cam sensors. It can cause major engine issues.
P0340 been the code Ses, vdc, and slip lights been on.
Exactly. They come on in light show.
Old Aug 26, 2014 | 10:45 PM
G35inRome's Avatar
I am having the exact same problem on my 03 G35, however there are no warning lights on, should I dismiss the camshaft sensor solution because of this? or is it possible that the warning light just happens to not be showing up?
Rome
Old Aug 26, 2014 | 11:41 PM
ScraggleRock's Avatar
Clean the throttle body.
Old Oct 11, 2014 | 11:05 AM
G35inRome's Avatar
Installed new throttle body, problem fixed for me.
Old Oct 14, 2014 | 09:37 AM
Mustang5L5's Avatar
I gotta do that one of these days.
150K miles...never touched the TB yet.
Old Oct 14, 2014 | 03:19 PM
If it ain't giving you problems consider yourself lucky and don't touch it. Can't stand that rotten thing.
Old Oct 14, 2014 | 03:31 PM
Mustang5L5's Avatar
Part of me says "If if ain't broke, don't fix it"
But at 150K, i've yet to touch a cam position sensor or clean the TB. Valve covers don't leak either.
(knock on wood)
Old Oct 14, 2014 | 03:39 PM
(knock on wood)
When they say valve covers leak, are they talking about on the outside or the leak that pools up a bit in the spark plug cavity?
Old Oct 14, 2014 | 03:41 PM
Mustang5L5's Avatar
Both, but more commonly inside the spark plug wells.
Last time i looked (around 120K miles) it was dry.
I should prob take a peek now.
Now if i can only solve my damn oil consumtion problem. Installed a new PCV over the weekend. Lets see if that helps.
I'm down 2 quarts per 3K miles. I just carry a quart with me all the time and add it as needed.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
Wayne9011
Jul 27, 2015 11:25 AM
laksjd84
Jul 24, 2015 05:12 PM
