Getting new Struts/springs. does it matter if AWD or not?
Old Jan 24, 2013 | 02:32 PM
Mejiseike's Avatar
i was looking into buying some new struts and springs or maybe coilovers and was just wondering if it made any difference between the sedan and the AWD sedan when buying suspension.
Old Jan 24, 2013 | 03:04 PM
The Fixer's Avatar
Yes, the AWD G has a bracket that bolts to the strut, which then goes around the axle shaft. So, you cannot use RWD struts on the front of an AWD G. But, the springs are the same for RWD and AWD. Check out my pic of the strut bracket here -
As far as aftermarket struts, there are only KYB Excel G's available for the front of an AWD G. That's what I just put on my '06x.
Rear suspension is exactly the same as a RWD G35 or 350z.
Old Jan 24, 2013 | 03:18 PM
Mejiseike's Avatar
KYB is the only ones to sell struts for the car?
Old Jan 24, 2013 | 03:41 PM
The Fixer's Avatar
It's KYB or OEM if you want to keep a stock-type strut assembly up front. There are aftermarket coil-overs available as well, but I have done no research on them since I wasn't planning to lower my car much at all. I only swapped in coupe front springs to even out the fender gap with the rears. I have no plans to go lower - need ground clearance for snow and bad weather.
Old Jan 24, 2013 | 07:25 PM
Mejiseike's Avatar
and how is the ride on those?
Old Jan 25, 2013 | 11:02 AM
lieb923's Avatar
Smile AWD Front struts
Monroe makes a similar design twin tube gas filled shock.
The are a old time mfg. Not sure of their present day quality.
#71143 (lt)
#71144 (rt)
YMMV!!!!!!!
Old Jan 25, 2013 | 06:48 PM
The Fixer's Avatar
So far, no complaints at all. I only have a few hundred miles on them since install, but they feel great. I ordered mine through RockAuto.com - quick shipping and fair price.
Old Jan 26, 2013 | 05:16 PM
Mejiseike's Avatar
They aren't too soft? Cuz i still want a lil sporty feel to the car
Old Jan 26, 2013 | 08:20 PM
The Fixer's Avatar
They are about the same as stock - maybe a tad stiffer. They're definitely not mushy, so don't worry about that.
Old Apr 23, 2013 | 09:47 AM
yosip1115's Avatar
Is it possible to modify a pair of RWD tokico blues to fit the AWD bottom mounting bracket? Seems pretty simple but ****, I already bought some tokicos, man I messed up.
Old Apr 23, 2013 | 10:04 AM
ccc123pm's Avatar
X
The rear shocks are not a problem. look at the picture above and look at bottom of your front tokicos... there is your problem. You would have to weld on a collar without ruining the internal gas/hydraulic system.
xx7sephiroth7xx
Brakes
May 3, 2023 07:07 PM
Danielek
May 1, 2022 01:28 PM
Fox843
Nov 7, 2015 05:43 PM
