04 sedan 5at no low end power
Old Mar 2, 2013 | 04:48 PM
Jakenbake2009's Avatar
I have a 04 sedan automatic and it seems to have no power till after 3500rpms. I know that it won't have a ton of power till after then but it seems to have way lower than what it should be. If I floor it from a start it stalls for a sec then slowly speeds up to 3500rpms then it kicks you back in you're seat. Is this normal or is something wrong? I keep reading about how people are doing burnouts in their 5ats and mine would never be able to do that. I only have like 120,000 miles on it. Well maintained. Any thoughts? Thanks
Old Mar 3, 2013 | 03:21 PM
Anyone??
Old Mar 3, 2013 | 03:26 PM
Blue Dream's Avatar
I drove ttrank's car solo
Does it seem to run smoothly at least? Did this just start or has it been going on the whole time you've had your car? How long have you owned it?
Old Mar 4, 2013 | 09:22 AM
Peoria35sedan's Avatar
Are you sure the car is shifting into low gear, put it in first using manual mode and see if it's the same.
Old Mar 4, 2013 | 05:53 PM
Caracicatriz's Avatar
If you are really stepping on it the VDC might be kicking in and retarding the acceleration. Try turning it off and see if it helps.
Old Mar 4, 2013 | 06:14 PM
JaE35's Avatar
Moderator
G35 Sedan
put it over in b!tch slap mode and turn off VDC lol
Old Mar 4, 2013 | 10:09 PM
5150DS's Avatar
Agreed, sounds like vdc. Button is on the lower part of dash on left side of steering wheel.
Old Mar 5, 2013 | 08:52 AM
Mustang5L5's Avatar
I'd think he'd be seeing the VDC light blinking in his face though...no?
EDIT: By that i mean the SLIP light
Old Mar 5, 2013 | 10:58 AM
5150DS's Avatar
Judging by his screen name he's probably too high to know what is happening.
Old Mar 8, 2013 | 02:18 AM
lowblocks's Avatar
Mines had the same problem until I did the efan mod to my car
Roblee22
Jul 30, 2015 12:11 PM
socalg35x
Jul 28, 2015 10:42 AM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
