Not shifting gears?
Old Mar 5, 2013 | 09:45 AM
Reedtc's Avatar
Angry Not shifting gears?
So yesterday while I was on my way to school I was cruising about 65 then I got onto an off ramp and slowed down a bit. My car suddenly slowed and jerked(downshifted) and my "Service Engine Soon" light came on. Immediately pulled to the side of the road & gathered my thoughts hoping that my transmission didn't **** up . Started my car again & it was still there . I drove to Autozone & got them to read the code, the only thing coming back was P1730 . I did my research on it & was only able to find a little helpful information. So today I figured I would try to drive to school & my baby wouldn't even shift for me . So i tried the tiptronic mode or whatever & when I shifted up the number on the dash would change but it would still sound as if I was in first gear pushing the revs higher and higher . Please tell me my transmission isn't shot
Old Mar 5, 2013 | 10:08 AM
gary c's Avatar
When I had a trans issue (fluid too hot) I got a trans warning and she went into limp mode. Take your G to Nissan and get this figured out, let us know the results....Gary
Old Mar 5, 2013 | 10:10 AM
Blue Dream's Avatar
I drove ttrank's car solo
Looks like it could be a number of things. I wouldn't try to diagnosis the issue myself, you should take it to a reputable shop and have someone look at it. If you go the dealership route, go to Nissan not Infiniti. It'll save you a few bucks.
Possible causes
- Low coast brake solenoid valve harness is open or shorted
- Low coast brake solenoid valve circuit poor electrical connection
- Fault low coast brake solenoid valve
- Faulty Automatic Transmission Fluid (ATF) pressure switch 2
When is the code detected?
Diagnostic Trouble Code (DTC) P1730 is detected when Transmission Control Module (TCM) does not receive the proper voltage signal from the sensor and switch.
Picture Share
Feb 4, 2018 12:41 PM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
