Shifting Noob!
Old Mar 20, 2013 | 04:54 PM
neo_anderson302's Avatar
Shifting Noob!
Is it ok to shift without the clutch pedal, if you in the right rpm range?
I did it a few times felt kind of smooth.
Thanks.
Old Mar 20, 2013 | 04:57 PM
dominate's Avatar
You definitely shouldn't be driving a manual transmission car if you asked this question.
Old Mar 20, 2013 | 05:10 PM
You think?
Some older guys at my job were telling me about it. We dont use the clutch pedal on our CDL trucks so...
Old Mar 20, 2013 | 05:18 PM
saywat?'s Avatar
wtf?
Old Mar 20, 2013 | 06:08 PM
GFly07's Avatar
You should be fine as long as the gear goes in without grinding.
Old Mar 20, 2013 | 06:09 PM
gary c's Avatar
Sure it can be done with practice, however how many times are you going to grind gears before you're looking at replacing the trans? Nissan supplied you with a clutch....use it!
Gary
Old Mar 20, 2013 | 06:11 PM
6mtg's Avatar
i would not recommend this beceause as most of us know we have weaker synchros as it is in pre 009 transmissions so i wouldnt risk the extra wear and tear on the trans
Old Mar 20, 2013 | 06:57 PM
Ok thanks for the helpful info.
Old Mar 20, 2013 | 06:59 PM
saywat?'s Avatar
I say try it and post results/experience!
Old Mar 20, 2013 | 08:22 PM
I did try it and it went into the next gear.
Old Mar 20, 2013 | 09:09 PM
6mtg's Avatar
It can be done i can do it all day long up shifting and down shifting but im saying its not the best.for the transmission
Old Mar 21, 2013 | 08:41 AM
Mustang5L5's Avatar
Use the clutch!
However, it can be done as I used to do it all the time in my Mustang. The thing was before it could do any real damage I used to blow the transmission up (Drag tires + clutch dump with 300+ ft-lbs torque = boom).
Yes, if you get good at it it could be done without much damage, but the clutch is there for a reason
Old Mar 21, 2013 | 09:09 AM
faiz23's Avatar
Old Mar 21, 2013 | 02:35 PM
saywat?'s Avatar
would doing this damage the gear lock mechanism? im assuming u have to shift quite hard to get it out of gear without the clutch. I don't ever plan on doing this was jus wondering
I didn't even know u could do this lol its like finding out santa doesn't exist. would this be a ghetto alternative to not replacing clipping clutches? for reals lol
Old Mar 21, 2013 | 03:20 PM
Switching the gears is relatively easy. Just have to be in the proper rpm band.
Fyi clutch pedal are for people who cant time their shifts.
