VDC light..is it on when I turn it off for RWD?
Old Mar 26, 2013 | 07:11 PM
x53G35x's Avatar
I rarely use VDC off. Nonetheless;
I have a 2005 5atx. I thought if I turned the VDC off, the light on my dash was supposed to light up?
I've tried turning VDC off a few times, with no response from the throttle or torque, and no lights on dash either.
Anyone?
Old Mar 26, 2013 | 07:18 PM
Geewhiz420's Avatar
when you press the VDC button, it should light up on your dash telling you it's turned off.
I have a coupe tho, but same diff.
Old Mar 26, 2013 | 07:22 PM
x53G35x's Avatar
Hrm. I wonder why it's not. Anyone know what fuse its on?
Old Mar 26, 2013 | 08:50 PM
G2B35AGN's Avatar
I have a 2006 G35x and the dash light definitely comes on when you switch off the VDC.
Old Mar 26, 2013 | 09:26 PM
neo_anderson302's Avatar
Maybe your bulb is out
Old Mar 27, 2013 | 07:37 AM
Mustang5L5's Avatar
When you turn the key to the ON position, but don't start the car, does it light up?
Old Mar 27, 2013 | 07:54 AM
Jmforgey's Avatar
You should be able to break the wheels free much more easily if the VDC is truly off. Go around some turns and get on it a little. See what happens.
Old Mar 27, 2013 | 08:57 PM
x53G35x's Avatar
Anyone know what fuse that side of the dash is on?
Old Mar 27, 2013 | 08:59 PM
x53G35x's Avatar
No. I get the 3 in the rpm and 2 red on the left but all go off when I start the car.
Old Mar 27, 2013 | 09:18 PM
G2B35AGN's Avatar
I ask this as a new G35x owner that is still "feeling her out" and hasn't yet tried VDC off: would this be true for the AWD sedans (which is what I believe the OP has)?
Old Mar 28, 2013 | 08:45 AM
Mustang5L5's Avatar
Ok, i don;'t know what those other lights are, but pretty sure the VDC OFF light should turn on during gauge test when you turn the key to on.
Kinda tells me the bulb is burned out. Hard to get those bulbs however.
It defaults to ON when you start the car. 1 press will turn it off
Old Mar 28, 2013 | 08:46 AM
Mustang5L5's Avatar
It's a little harder to do because the AWD system still functions with the VDC off. Get on it hard in a corner and slide the rear a bit and more power gets sent to the fronts which quickly dulls the fun. Nowadays, i only turn the VDC off in the snow when trying to parallel park into a snowbank.
Old Mar 28, 2013 | 12:03 PM
roadganstah's Avatar
I seen somewhere on this forum that wire switching the abs module could make the X models to become RWD instead of AWD. And for even more output, putting a switch on the yaw sensor in center console would disable even more. Never tried though, only read from forum.
Old Mar 28, 2013 | 12:53 PM
Mustang5L5's Avatar
Yanking the AWD fuse will do this. Basically the Xfer case is electronically controlled. By applying power, you can control how much the clutches grab. Yanking the fuse will kill the power causing the xfer case to remain "open"
However, this isn't an official way to make your AWD car now RWD. I'm not going to personally suggest trying this.
Old Mar 30, 2013 | 05:23 PM
x53G35x's Avatar
Ok so I looked in the driver side fuse box and seems all the fuses are there. I will test the all in the next day or two. I did notice a single gray wire running from beside the footbrake to the fuse panel was just dangling loose. I didn't pull it, but could be part of the time you problem. I wonder where it's supposed to go... I'll take a picture with my phone this PM and hopefully post it.
To make myself clear re: wire -. I opened the fusebox and the wire was exposed, hanging there. I traced it upwards, behind all the plastic and couldn't trace it further then the footbrake.
