Brake squeak new oem pads
Old Apr 2, 2013 | 07:46 AM
neo_anderson302's Avatar
I just had new oem pads and hub bearing installed. Also aftermarket rotors put on. After 30 mi my brakes squeak pretty loud about 50% of the time. The installer never applied any brake grease. Could this be a issue?
Old Apr 2, 2013 | 09:35 AM
Mustang5L5's Avatar
It could be. Definitely my first move would be to remove the pads and apply the break grease to the backside of the pads on the contact surfaces.
It could also be the rotors as aftermarket parts can sometimes be noisy, but try the grease first
Old Apr 2, 2013 | 11:27 AM
Yea Im try that. Also I heard it could be the dust shield not on right.
Old Apr 2, 2013 | 01:30 PM
Mustang5L5's Avatar
Well, they should have never touched that, but it's possible it's bent and scraping the rotor. But you'd hear that all the time and it would get faster and slower as you speed up and slow down.
Old Apr 2, 2013 | 06:23 PM
Blue Dream's Avatar
I drove ttrank's car solo
Did you bed in the pads properly? That will cause noise as well but you definitely need to add the grease like Mustang said.
Old Apr 2, 2013 | 09:36 PM
Well when he replaced the hub bearing the dust shield just fell off since its connected to it. I was there the whole time.
Old Apr 2, 2013 | 09:38 PM
I really can't say yes. I hear it the most when I brake at low speeds and turn the wheel. Its like 50% hit in miss when I brake straight on.
Old Apr 2, 2013 | 09:45 PM
herrschaft's Avatar
Grease them first and go from there. The dust shields are easy to check.
Old Apr 2, 2013 | 09:48 PM
Yea the mechanic is doing it monday, he said he never applies it and never has a issue. I guess thats why he said his car does it too. lmao.
Old Apr 3, 2013 | 08:26 AM
Mustang5L5's Avatar
Wow
I've done tons of brake jobs on my cars over the years. Only times i get squeaks are when i forget to buy grease and get lazy, or buy cheap *** autoparts store parts.
OEM pads should be silent...kinda why i've put 3 sets on my G35 so far.
Old Apr 3, 2013 | 10:52 AM
If you dont add the grease, what parts make the noise the grease helps prevent?
Old Apr 3, 2013 | 11:02 AM
Mustang5L5's Avatar
The noise is caused by vibration due to contact between the pad's backing plate and the caliper itseld.
The grease is applied between the contact points to provide lubrication between those points. The squeak is actually high frequency vibration.
Old Apr 3, 2013 | 12:55 PM
Ok got you
Old Apr 3, 2013 | 03:09 PM
ristau5741's Avatar
I've been having a similar issue for about a year, since I last had my pads replaced. squeaking when I lightly press on the brake pedal, as I depress the pedal more, the squeak stops, I've took it back, and the pads were replaced again, though I was told that it was the brake pads themselves. anyhoo, squeak came back a few weeks later. more annoying than anything.
Old Apr 3, 2013 | 03:19 PM
They greasr them?
miata007
Aug 17, 2015 04:36 PM
sahizzle110
Jul 29, 2015 11:36 AM
ddietz97
Jul 26, 2015 06:16 PM
mushu
Jul 15, 2015 03:55 PM
