Anyone have H&R Springs on their Sedan?
Old Jan 30, 2005 | 09:12 PM
Gting's Avatar
Anyone have H&R Springs on their Sedan? I can find anything in the forums regading pics or review of the H&R on the Sedan?
Old Feb 5, 2005 | 01:25 AM
ghostrider71's Avatar
it's not QUITE the same, but there's quite a few guys who've put H&R's on their Maximas recently.
www.maxima.org
They seem to be a bit more plush than sporty, and the drop is not particularly even with the front being higher than the rear.
NOt a great comparo -- but thought I'd try.
gr
Old Feb 5, 2005 | 01:27 PM
Gting's Avatar
www.maxima.org
gr
I dont think it is the same camparo. The Maxima looks wise does not drop enough in the front. Not all h&r are the same on all cars. Check this one with hr
I can't find a solid close side view to see if it is an even drop:
http://www.cardomain.com/memberpage/703701
Old Feb 7, 2005 | 12:39 PM
tony2003's Avatar
H&R
I have an 2003.5 MT sedan. I put the H&R springs right before winter and I've been riding on them for about 4mths. I can tell you that they are great. I can't wait to put my summer tires back on and really test out the ride. The drop was just right around 1". They resulted in less body role and better cornering but the ride is somewhat stiffer. I personally love it. Hope this helps.
Old Feb 7, 2005 | 01:22 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
The H&R site lists the drop data as;
Sport Spring 3.5L, V6 1.3fr 1.2rr part# 53036
Old Feb 7, 2005 | 08:02 PM
Gting's Avatar
Thanks! Did you keep your stock struts on? Did you cut the bump stops at all? Does there seem to be more wheel gap in the front than the back? ie. the backend a little lower than the front?
Old Feb 7, 2005 | 08:03 PM
Gting's Avatar
THe site says that but experience is better. They have been know the be off on a number of applications ie. the maxima.
Old Feb 19, 2005 | 12:31 PM
tony2003's Avatar
I did keep the stock struts on. There was also no cutting involved. Pretty much take out the old and put in the new. As for the wheel gap difference, I know that before I put on the springs it was a little uneven (or at least it seemed that way to me) but now with the H&R springs it seems to be fine.
As for the listed drop, I'm assuming that with time the springs will settle.
jsimonk
Dec 22, 2023 03:49 PM
si_driver
Aug 11, 2015 07:08 AM
andresito7
Aug 1, 2015 04:53 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
Scredeur4
Jul 17, 2015 06:30 AM
