Rattle When Turning Left Slowly
Old Jun 7, 2013 | 12:25 PM
vanharca's Avatar
For the past few months I have had this rattle and it's driving me nuts. It only happens when I am gowing slowly and turned sharply to the left, mostly while pulling into driveways or in parking lots. It sounds metallic like a heat shield, but I don't know why it would only happen while turning if it were a heat shield. I have been under the car and everything appears to be solid. If anyone has experienced this and fixed it I would really appreciate any advice.
Thanks!
Old Jun 7, 2013 | 01:56 PM
vanharca's Avatar
Sorry, model would probably help - 05 6MT Sedan with roughly 115,000 miles
Old Jun 7, 2013 | 02:12 PM
Mustang5L5's Avatar
Brake dust shield? Can you have someone walk alongside the car to help pinpoint the origin?
Old Jun 7, 2013 | 03:43 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
I had something similar, it sounded about like a piece of rebar being dropped on the ground. Turned out the tire pressure sensor had broken off from the valve. Whenever the wheel was spinning fast enough, centripetal force kept it pushed against the inside of the rim, but when moving slow it would roll around inside making a metal rattling sound.
It's easy to check if this is the case - jack up the offending corner enough that you can spin the tire freely and see if the sound happens.
The pressure sensor survived the abuse, and I was able to re-attach it to the valve with some epoxy, just be sure you prevent airflow through the valve.
Old Jun 7, 2013 | 04:25 PM
ItsA..Gthing's Avatar
Rattle Snake...
Old Jun 8, 2013 | 09:57 AM
bigjee's Avatar
Thanks!
Does it happen when you make sharp U turns?
Old Jun 9, 2013 | 06:37 AM
GreenPenguin's Avatar
I wonder if our issues are the same. I posted in the RLQT a few days ago about mine. Try this: get up to like 35 mph then put her in 6th gear and try to accelerate. If you hear the rattle, we have the same issue. No idea what it may be but I may be going to the stealership soon.
Old Jun 10, 2013 | 12:11 PM
vanharca's Avatar
It doeshappen when making sharp u-turns, but only when turning left, not right. I'll check the tpms sensor idea tonight maybe.
Old Jun 23, 2013 | 04:23 PM
Jlaud's Avatar
Check the brake dust shield as mustang said. I had the exact same problem and that's what it turned out to be.
Old Jun 23, 2013 | 04:43 PM
5150DS's Avatar
If not those things, might be wheel bearings.
chinee
Jun 10, 2024 07:48 PM
MsFitFern
Aug 9, 2015 02:58 PM
kinetek
Aug 3, 2015 04:25 PM
