Knocking in the engine after warm-up
That doesn't sound good. Why don't you give us some more specifics? Like, what temperature are you warming up from? (ie the temperature outside) and do you NOT hear the knocking when it's still cold? What gear / speed do you have to be in/doing to reproduce this knock?
...Also are you talking about true engine knock with a metallic rattling or pinging sound? Or are you talking about an actual knocking sound? Some amount of engine knock should be expected if you're going to put it under a large strain but it's never a good thing. If it's true engine knock you also might let us know what quality of gasoline you're using.
Twice I have noticed engine knock... once with low octane gas (89) and once when oil was near its time to be changed... but it wasn't low.
Check oil level and if abnormally low, take straight to dealer shop. If ok then try higher octane gas (92 or 94) -- if you are running bad gas then it may take more than one fill to remedy. If after second fill it still knocks after the car has had a chance to warm up then..take to dealer.
Originally Posted by BbyG35
Poor noobie... simple question gets so much sarcasm spilled over from another 9 page (and counting) thread.
