window keeps opening
https://g35driver.com/forums/interio...procedure.html
basically you need ro reprogramm the window stop limit switches. For some reason the car has forgotten them on that window. What happens is the window tries to close past it's full closed point and thinks it's pinching something in between the glass and door frame. So it stops and opens the window slightly as a safety feature.
You need to reprogram the limit switches. This involves pulling the door panel off the offending door which is very easy
BradMD_96
Oct 6, 2015 09:31 AM
Learned Hand
Oct 1, 2015 09:02 AM
