p1757 code and a locked out transmision
Old Jul 2, 2013 | 01:32 PM
nazc0's Avatar
2006 Vortech supercharged Sedan
So just as I did my belts, and installed my intake, I get a p1757 code for my tranny solenoid and it feels like its stuck in 4th gear. When I just start it it will drive fine for a minute and then just lock the tranny out. So mechanically my tranny is fine but once the code pops back up then I'm stuck in 4th again. If it wasn't for a strong engine my car would be useless but it can still drive almost normally with traffic in the city
I've looked around on the forums and all I can come up with is I need a new transmission
Has anyone ever experienced this problem? I haven't done a tranny flush in 60k so I scheduled one with the dealer but I want to know if its even worth flushing the fluid or should I start looking for a good used tranny? Mine has held up to 160k miles and the last 70k have been hard but it still drives butter smooth and my tranny never clunked or shifted harsh so I hope I can still fix this and keep on driving, I was just going to paint the whole car
Old Jul 2, 2013 | 07:48 PM
strozyk's Avatar
My g threw a 1759 its a brake solenoid in the transmission and it had similar symptoms I took it in to infiniti and had the trans serviced and it fixed it. Also from what I understand all those solenoids are on the valve body so i don't think you would have to replace the whole trans
Old Jul 3, 2013 | 05:06 AM
Blue Dream's Avatar
I drove ttrank's car solo
My guess is you're going to have to take it to a mechanic and possibly the dealer for service. Since the code points to the transmission hopefully it's a simple as replacing that solenoid. Good luck and let us know what the issue was and how it was fixed.
Old Jul 6, 2013 | 11:42 AM
nazc0's Avatar
well the deealer was a waste of time they looked at the codes and instant response was to get a new tranny for 3k but they did offer a re manufactured tranny for 1.5k.
I left a car at a good transmission shop and they told me to come back in 2 hours... I came back in 2 hours and they were closed now i have to wait till monday
Old Jul 11, 2013 | 02:20 PM
nazc0's Avatar
so i was told a new valve body to fix the tranny but 1000 for the valve body is way o much to put into a 160k tranny so im going with a used one from an 04 coupe that has 30k miles on it and only costs 750
Old Jul 12, 2013 | 10:26 AM
KingoftheRoad1's Avatar
Hey nacz0, this guy had the same problem as you and had it fixed. You should follow the same route!
Old Jul 12, 2013 | 12:04 PM
nazc0's Avatar
A shop confirmed its the valve body not the individual solenoids so 1000 for a valve body to go in a tranny that has 160k is a stupid waste of money, I found a used tranny for 750 that has 32k miles on it but its from a coupe and I was told it won't work, anyone know that for sure?
Old Feb 3, 2014 | 01:51 AM
a-Sarkar's Avatar
P1757
My SES light popped on while driving today, and also experienced the loss of power or "4th gear" pull. Checked the codes, and the code p1757 came up, which you seemed to have experienced, hopefully its the solenoids and not the valve body. But just out of curiosity, did the tranny from a coupe fit and fix your issue?
Old Feb 19, 2014 | 05:14 PM
nazc0's Avatar
yes transmission fits perfectly, no problems now all i need is a lsd
Old Feb 19, 2014 | 10:15 PM
a-Sarkar's Avatar
Ah glad to hear, I brought it to 2 different tranny mech's and both said valve body, and so it's at the stealership at the moment getting it replaced for $2300.... Quite a kick to the nuts for having had the car for only a year..
Old Feb 20, 2014 | 01:11 AM
5150DS's Avatar
Is that just for the valve body?
Old Feb 20, 2014 | 01:22 AM
a-Sarkar's Avatar
Yeap, I live up in Vancouver BC. Just the valve body at the dealers here is mid $1600, + 3 hours of labor, + tranny flush, + our ridiculous 12% tax..
Old Feb 20, 2014 | 01:56 AM
nazc0's Avatar
exactly why i just opted for a used trans, if my stock one lasted almost 170k ill be good with this one for a while, on the other hand when i do decide to replace my engine im converting it to a manual one
Old Feb 20, 2014 | 02:07 AM
a-Sarkar's Avatar
Makes sense, mines currently sitting at 83k-ish miles, so definitely iffy about replacing the whole trans but decided to look anyways and couldn't really find any much lower than my current k's. So just gonna have to bite the bullet and postpone my plans for a few of my wanted mods for the summer
Old Feb 23, 2014 | 04:22 AM
a-Sarkar's Avatar
Just an update on my situation, had the valve body replaced, and all is well. After not driving it for about 2 weeks, it feels like driving a new car.. Total cost from the stealership was $2554.20 after taxes. This included valve body, 3.5 hours of labor, transmission flush, gasket, and diagnostics.
