Halogen Bulb Replacement!
Old Oct 29, 2013 | 02:22 PM
Texasscout's Avatar
It's not an opinion. it's a fact, "I have had no trouble" YMMV.
Old Oct 29, 2013 | 02:27 PM
saywat?'s Avatar
I was referring to this reply
Originally Posted by Texasscout
Bulb wattage is a relative game. What we have here in the US is marked 55/65 watts. The Euro bulbs are marked 65/100 or even 120 watts, it's all bullshit. The draw the same wattage and give relatively the same light output. It's the way the Europeans measure wattage.
Old Oct 29, 2013 | 03:51 PM
Mustang5L5's Avatar
True, but that's a dangerous blanket statement to make as the OP could grab a set of bulbs that DO have higher power draw. In that case, he could potentially damage his system.
Safest thing to do is to assume that if the bulb says 55W on it, then it actually draws 55W. Until one grabs a digital multimeter and measures the current draw, then there's no technical proof the bulb's spec is anything other than stated.
Old Oct 29, 2013 | 04:38 PM
saywat?'s Avatar
its like saying u bang girls with stds and never got an std therefore its ok to bang girls with stds. lol
Old Oct 30, 2013 | 09:15 AM
Texasscout's Avatar
In a way, yes. But I stand by what a I said. No problems.
Old Oct 30, 2013 | 02:11 PM
Mustang5L5's Avatar
Old Oct 30, 2013 | 02:25 PM
Texasscout's Avatar
I have run stuff like this for years:
http://www.autobulbsdirect.co.uk/H4-...-pair-NEW.html
They SAY that they are 130 watts, but if you look close they say 130 watts of OUTPUT, the input wattage on the package says 55/65 watts. That's why I say the euro bulb wattage ratings are BS.
Old Oct 30, 2013 | 06:39 PM
saywat?'s Avatar
it says 90watt
Old Oct 30, 2013 | 08:17 PM
Texasscout's Avatar
Direct copy from the website : Rated at 130/90W
That's 130 watts HIGH beam and 90 watts LOW beam.
Read it and don't just post without reading and UNDERSTANDING what you read.
Old Oct 30, 2013 | 08:29 PM
saywat?'s Avatar
Lol that's wat I said 90 watt. However looking closer at the pic package it also says "not standard 130watt". Watever that means. But ok so rarely left on high beams are 130 watts. And the lows are the fogs. Do u use them often like u do the hid lows?.
Old Oct 30, 2013 | 08:56 PM
saywat?'s Avatar
I'm guesing wat ever brand ur using is jus using some marketing to word there bulb differently than wat were used to. . Rather than says "produces more light output than standard bulbs" they put a calculated output figure but the wattage is technically lower. that's why theres 2 wattages on the package. Has nothing to do with Euro vs us spec. Silverstar does something similar but says "50% more output than standard bulb". So its jus marketing. Most bulbs will jus have one rating on the package tho. I guess ur brand took a different approach n that's why u have no issues from years of usage becus ur bulbs are actually the correct wattGe to begin with.
Old Oct 30, 2013 | 09:26 PM
Texasscout's Avatar
Yes, this time of year I frequently drive an hour in the morning with them on and some time in the evening I run them for the same, depending on the time of year. I run mostly farm to market roads and not main highways where you can't run your high beams much.
Old Oct 30, 2013 | 09:27 PM
Texasscout's Avatar
Exactly what I have been saying.
As for the Euro spec, yes it does. Most of these bulbs only draw 55/65watts actual, but they say the "light output" is equal to 90/120 watts. So naturally people think they are brighter. That is a function of the color temp (how we perceive the amount of light) and the actual lumens.
Old Oct 31, 2013 | 09:52 PM
markc's Avatar
That is also a function of advertising.
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
