front brake maintenance
Old Mar 3, 2014 | 09:18 AM
clearwaterms's Avatar
Brakes front brake maintenance
I am going to be replacing the brakes on my 06 G35x this spring. This is a daily driver and isn't driven very hard (no performance pads needed) The pedal feel is perfect right now, but the car does have a slight wobble when you apply the brakes at speed (warped rotors). The car has 76k miles.
I would like to order parts online to save some bucks.
What pads do people typically recommend for daily drivers?
If the pedal feels good should I just top off the brake fluid or flush the system? If I do a full flush, any harm in doing it by just pumping it through the bleeder screw ensuring to keep the reservoir full with clean fluid and use a clear hose and when I see clean fluid, just bleed the system and call it good?
Is there anything else that I should replace / clean / inspect while I am in there?
Thanks
Old Mar 3, 2014 | 09:56 AM
LoSt180's Avatar
I've always recommended Akebono ProACT pads for a DD. Good stopping power and very low dust. For rotors, I usually order Centric. StopTech, Powerslot, etc all start with a basic Centric rotor, order from the source, save a few bucks.
Bleed/flush the system is fine. Brake fluid should be replaced periodically.
Inspect the dust boots on the brake calipers, also inspect all bushings and ball joints while you have the wheel off.
Old Mar 3, 2014 | 10:09 AM
thanks for the fast response. I am putting a shopping cart together on rock-auto right now. They have several Centric parts to choose from. Which one specifically do you like the best? the price differences are not all that high.
Centric Standard Disk - $29.79
C-Tek: Sport Drilled & Slotted - $47.79
Premium preferred - $56.79
Premium cryogenically treated - $68.79
High Carbon Allow - $64.79
Stoptech sport drilled - $94.79
stoptech sport drilled/slotted - $96.79
Again, this is just a commuter / daily driver so I am thinking the premium preferred or standard disk.
I found the pads on the site, so I think it's just the rotors and I can place my order. Thank you
Old Mar 3, 2014 | 10:46 AM
LoSt180's Avatar
I think the difference between the standard and premium is that the premiums come with E-coating so they don't rust. The premiums have some additional machining and balancing done also. Probably worth the few extra bucks.
I personally run the high-carbon version, but I'm also running Carbotech performance pads.
Old Mar 3, 2014 | 10:53 AM
Gman56's Avatar
I ordered from tire rack akebono pro act for $47 and stop tech drilled rotors $85 a piece. Fast shipping 3 days to my door!
Old Mar 3, 2014 | 04:41 PM
Mustang5L5's Avatar
I run OEM pads on my car. The stopping power has been fine, but the key points to me are low dust, and noise. My car is a daily driver so it's all I've ever needed. I've done 3 brake jobs with OEM pads.
Rotors are a different story. I replaced OEM with OEM once and they warped quickly. I think my next time around I went with Stop-tech and they have done quite well and resisted warping.
For brake fluid flushes, i flush my fluid yearly and always feel a difference. I use the Valvoline Synthetic fluid, and use a clear hose while a friend pumps a pedal method.
INSPECT your rear brakes. The caliper slide pins are notorious for seizing up and causing rear brake issues and soft pedal feel
Old Mar 3, 2014 | 04:58 PM
saywat?'s Avatar
anyone notice in the owners manual its says not to use synthetic brake fluid in the reservoir. why? idk. but centric rotors and stop tech pads FTW!
Old Mar 3, 2014 | 05:02 PM
Mustang5L5's Avatar
Yes
All brake fluid is synthetic. They aren't petroleum based and do not exist naturally. What i'm willing to bet is that is meant to imply to not use DOT 5 silicone based fluid
Old Mar 3, 2014 | 05:04 PM
saywat?'s Avatar
ive been told all brake fluid is syn as well. yet ull see certain fluid that explicity say "synthetic" on the packaging while most others don't. I don't get it lol
Old Mar 3, 2014 | 05:16 PM
Mustang5L5's Avatar
Marketing....
For the most part, synthetic is looked to mean "the best"
WHen someone buys a car, and knows absolutely nothing about cars, but gets excited about it what's the first thing they do??? Synthetic oil!
Because they can not know a damn thing about cars, but know that synthetic must mean best!
Synthetic fluids, premium fuel (vs regular), spark plugs made out of unobtainium.....all good marketing strategies
Old Mar 3, 2014 | 07:46 PM
Urbanengineer's Avatar
My dealer recommends Infiniti OEM Synthetic wiper fluid why shouldn't I go with it? It must increase hp...
Who can argue with 10k mile oil changes?
derres
Aug 28, 2015 03:27 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
kinetek
Aug 3, 2015 04:25 PM
wojowojo16
Jul 27, 2015 09:57 AM
korfak
Jul 20, 2015 12:10 PM
