Strange Creeking Sound
Old Mar 13, 2014 | 09:43 AM
DailyX's Avatar
My 06 sedan is making a creeking sound which I'm pretty sure I have pin-pointed to where the driver side fender meets to hood hinge. I bought the car a few months ago and could tell there had been an issue with the hood edge rubbing the fender edge, after some research I found this was/is a common issue. But now there is this creeking noise which is very annoying/noticeable from inside the car while driving. When I push down on the hood corner (where it was rubbing) I can hear what seems to be that sound. Should I be right to assume the noise is coming from faulty/worn out hood hinge?
Thanks guys!
Old Mar 13, 2014 | 10:39 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sounds like you're on the right track. First I'd lubricate both hinges and if that doesn't stop the noise replace the bad hinge.
Old Mar 13, 2014 | 10:42 AM
DailyX's Avatar
Thanks for your reply. I've been reading into replacing the hinge(s) and it seems they are much more involved than changing your average hood hinge. Am I right when I say the whole front end and fender needs to come off just to change that hinge?
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
