Steering Yaw Sensor
Old Mar 14, 2014 | 10:36 AM
shawngrace5's Avatar
Steering Yaw Sensor
04 G35 Sedan. Just did an engine swap and the only problem I'm having is the slip and vdc lights come on as soon as I move the steering wheel. Doesn't even have to be in drive, as soon as I move the steering wheel the slip and vdc lights come on and stay on.
Any help? All the fuses under the hood and under the kick panel are in good working order.
Old Mar 14, 2014 | 02:07 PM
Urbanengineer's Avatar
I think the yaw sensor is somewhere under the center console.
Old Mar 14, 2014 | 02:15 PM
You think its bad? or need a re-learn?
Old Mar 14, 2014 | 06:15 PM
It only throws the Slip light and VDC light when I turn the wheel to the left. If I start the car and turn it to the right it doesn't do it, but if I go to the left of center at all........... it throws the lights
Old Mar 14, 2014 | 07:28 PM
saywat?'s Avatar
wat up yaw
Old Mar 14, 2014 | 08:47 PM
Any better thoughts? lol
Old Mar 16, 2014 | 06:55 PM
Mustang5L5's Avatar
Are you moving when the light comes on? or just sitting still turning the wheel?
Any other warning lights on in the dash?
Old Mar 16, 2014 | 11:53 PM
AARONHL's Avatar
How about the sensor that is screwed to the steering spiral cable behind the airbag? Are you sure the alignment is straight enough and no air bubbles in brake lines?
brianuc4
19
Apr 10, 2020 02:12 PM
sullivan72
Sep 22, 2015 11:39 PM
DG2Door
Sep 11, 2015 08:04 PM
UT G35
Sep 3, 2015 03:58 PM
Kicknshift
Sep 3, 2015 09:35 AM
