K&N Part Number for 2005 G35
Old Feb 11, 2005 | 11:14 AM
deadstroke's Avatar
K&N's web site doesn't list a drop in air filter for the 2005 G35, the part number they have listed for the 2004 is 33-2031-2.
Has anyone put a K&N in the 2005's.
Old Feb 11, 2005 | 12:01 PM
dklau33's Avatar
I would bet nothing has changed about the stock airbox and filter and I haven't seen nor heard anything to that affect. You should be able to use the 2004 model K&N filter in your 2005 car.
Old Feb 11, 2005 | 01:37 PM
G35sedanman's Avatar
You could find out if the stock air filter is the same for 04 and 05 fromInfiniti. If it is, the 04 K & N drop in should be fine.
Old Feb 11, 2005 | 01:50 PM
mikeee2's Avatar
I thought about doing that too. I heard it won't have much of a performance gain if at all. Let me know after you put it in. I want to know if it makes the car's humming noise a little better at higher rpm. If it is, then I'll probably do it just for the sound since the sedan's exhaust doesn't sound nearlyyyyyyy as good as the coupe.
Old Feb 11, 2005 | 03:09 PM
I have a K&N drop in in my 2004 and it does not do anything for sounds. The exhaust note is still the same.
Old Feb 11, 2005 | 04:02 PM
gspotter's Avatar
If you want a better sound, get a ZTube installed.
Old Feb 11, 2005 | 04:26 PM
DWG-35's Avatar
I put the 33-2031-2 in my '05 6MT. No problems with the install since the dimensions were the same. I also installed the Z-Tube. It took a total of about 5-8 minutes to do both. Very simple and a better intake sound on full throttle.
Old Feb 11, 2005 | 06:11 PM
mikeee2's Avatar
Oh well, there goes that idea.
Old Feb 11, 2005 | 06:16 PM
mikeee2's Avatar
Maybe I'll consider the Z-tube one day or do you mean the Z-tube + pop charger?. For me that Z-tube's couple horses won't make much of a difference but I think the sedan's exhaust is not throathy enough. So I am sure with more sucking in air on the Z-tube the car should sound better even if it's not any faster. For now, stock is fine with me. Just don't want to hear anything when I have to bring car to the dealer.
NemesisGee
Aug 11, 2015 07:10 PM
Crappyday
Jul 28, 2015 04:07 PM
stay_tuned
Jul 21, 2015 07:09 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
hrdwirk1
Jul 14, 2015 05:46 PM
