Fuel gauge problem. Detailed.
Old Oct 22, 2019 | 05:43 PM
  #106
flipmode007's Avatar
Originally Posted by 4mermarine
So I might have spoken too soon. Gauge was at 3/4 tank last night when I got home. Fired up this morning and it goes to the full mark. ??? By the time I got to work it slowly fell back to where it should be at slightly under 3/4. What gives? Am I looking at the cause being something entirely different now, like flipmode007 refers to about the AMPLIFIER CONTROL AIR CONDITIONER 277601NM6D? Has it been that thing the whole time? I guess I'll try to find one and replace it next. Sheesh
Try that I have told a lot of ppl on youtube also and they were happy, they had change it and not spend so much money lol. when I go to a scrap yard I take them cuz here in canada its $400 for that part new
Old Oct 22, 2019 | 05:49 PM
  #107
4mermarine's Avatar
I just bought one used for $40 and will get it Friday. I'll let y'all know.
Old Oct 22, 2019 | 09:04 PM
  #108
keep me posted tks
Old Oct 22, 2019 | 09:16 PM
  #109
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Verify the sending units are sending out the proper 4-40 or 4-80 ohm resistance at the pump harness, really easy to check. It's covered in section DI - Driver Information of the FSM.
You might have a sending unit failure now, but had the instrument cluster issue previously.
https://www.nicoclub.com/archives/in...e-manuals.html
The AC Auto Amp is also a possible culprit if you have proper resistance signal and a functioning instrument.
You should also check resistance at the pin on the harness for the instrument cluster, I can't remember the pin number but I think it's in section DI as well. That way you know it's not a wiring issue between the pump and the cluster.
Old Oct 23, 2019 | 11:40 AM
  #110
4mermarine's Avatar
I've replaced both sending units even though the originals were cleaned and showing the proper resistance. I didn't test the new ones individually, but they didn't change the misbehavior of the gauge after I installed them, nor did the re-solder of the gauge cluster resistor points. I haven't tested the resistance at the pump harness or the instrument cluster pin yet. Thanks for the tips, I'll certainly do so since I'm running out of components to replace. Such a squirrely issue, but I'm determined to flush this thing out in the open one way or another. More soon...
Old Oct 23, 2019 | 07:13 PM
  #111
I did everything you've mention, I have like4 or 5 sending unit and 4-5 fuel pump just to show you how I went crazy from it lol.
Old Oct 27, 2019 | 06:14 PM
  #112
4mermarine's Avatar
Hey flipmode, where the heck is this AMPLIFIER CONTROL AIR CONDITIONER 277601NM6D located? Can't seem to find it on my 2006 sedan.
Old Oct 27, 2019 | 06:46 PM
  #113
Well on the 2009 its behind the radio unit. so it may be there too
https://www.z-car.com/lotus/files/2006-Infiniti-G35.pdf
Old Oct 27, 2019 | 07:04 PM
  #114
cleric670's Avatar
BANNED!!!
2006 it's behind the clock/compass. It's the top AC display and the controller is the white box behind it.
Old Oct 27, 2019 | 07:24 PM
  #115
4mermarine's Avatar
I'm real confused then. There's nothing behind the AC/clock display unit (just a metal frame) and it's not behind the radio either. I replaced the head unit a couple years ago and have it all pulled out.
Old Oct 27, 2019 | 07:58 PM
  #116
cleric670's Avatar
BANNED!!!
Ok the display itself, with the compass and temperature display, literally right behind those LCD screens is a big white plastic box that's all part of it and that is the AC Auto Amp. It's got a big 40 pin connector harness on the front of it at the bottom right corner.
Old Oct 27, 2019 | 08:16 PM
  #117
4mermarine's Avatar
Ok, so the whole unit then. That's 27760AC75A not 277601NM6D. Got one ordered.
Old Oct 27, 2019 | 08:31 PM
  #118
cleric670's Avatar
BANNED!!!
It looks like those are both the same item just for different years of vehicles. 27760AC75A shows as compatible with my 2006 so it should work for 2005-2007 coupe.
Old Oct 30, 2019 | 07:26 PM
  #119
4mermarine's Avatar
27760AC75A replaced and the issue/misbehavior remains.
To recap what I've done so far:
- Both fuel senders replaced, brand new.
- Cluster re-soldered in accordance with this post.
- 27760AC75A AC Auto Amp just replaced, albeit used.
Anyone have any other ideas? Meanwhile, I'm down to meticulously testing the wiring and such according to the FSM's. This is ridiculous.
Old Oct 30, 2019 | 07:45 PM
  #120
cleric670's Avatar
BANNED!!!
If the sending unit has correct resistance to the instrument cluster I would source a replacement cluster to test. There may be more resistors that need replaced beyond the ones listed in this thread.
