Torn intake coupler
Old Jul 7, 2014 | 11:41 PM
dc2long's Avatar
Torn intake coupler
Hello
So today I found a tear in my intake coupler. Has anyone else had this problem and how did you fix/replace it? Also will this throw any codes?
Recently I been having issues with my SES light coming on and off, code is P1084 EXHAUST VALVE TIMING VOLTAGE CIRCUIT BANK 2. I am wondering if this is maybe the cause of the light. I already tried replacing the sensor but it doesnt appear to fix the problem.
As of right now, I've duct taped it as a temporary fix until i decide on what to replace it with.
Old Jul 7, 2014 | 11:51 PM
Urbanengineer's Avatar
High temp silicone will do just fine. Really any glue that is slightly pliable and wouldn't fail under 200deg heat.
Old Jul 8, 2014 | 05:36 AM
5150DS's Avatar
I would look to jb weld or permatex epoxies.
Old Jul 8, 2014 | 08:55 AM
LoSt180's Avatar
Really guys? JB weld and glue for an intake coupler?
OP, yes intake & vacuum leaks can cause some weird issues. You can try to find a replacement coupler, or buy an OEM Z-Tube. The OEM z-tube has the couplers built in.
Old Jul 8, 2014 | 09:06 AM
Originally Posted by LoSt180
Really guys? JB weld and glue for an intake coupler? OP, yes intake & vacuum leaks can cause some weird issues. You can try to find a replacement coupler, or buy an OEM Z-Tube. The OEM z-tube has the couplers built in.
Cheap fix
Replacement couplers are cheap though yes... Try infinitipartsusa dot com.
Old Jul 8, 2014 | 01:02 PM
5150DS's Avatar
It is a temporary fix so the op can drive the car, hopefully without the lights/codes, till they can get a new part.
Old Jul 8, 2014 | 07:45 PM
dc2long's Avatar
Thank you for all your inputs.
I called infiniti and they do not sell the coupler piece by itself.
Option 1: try to find an oem ztube locally
Option 2: Go for the Stillen Ztube. I read a couple other threads saying the oem coupler would need to be reused to work with the Stillen Ztube. Can anyone confirm this?
http://www.thenismoshop.com/STILLEN-...X35_p_815.html
The picture in here shows a built-in coupler.
Option 3: http://www.z1motorsports.com/350_g35...oducts_id=3929
Has anyone tried this?
Old Jul 8, 2014 | 09:29 PM
5150DS's Avatar
Z1 is reputable, I have ordered from them before. The couplers will be cleaner than the accordian oem design.
Old Jul 9, 2014 | 08:57 AM
LoSt180's Avatar
The Stillen Ztube WILL need your OEM couplers, so scratch that option (I've had one before).
Looking at that Z1 intake, I bet you could just buy a silicon coupler and use that on your stock intake. Measure the MAF housing to be sure, but I think it's 3". Something like this: http://amzn.com/B004NYGSLE
Old Jul 9, 2014 | 10:30 AM
The Stillen Ztube WILL need your OEM couplers, so scratch that option (I've had one before). Looking at that Z1 intake, I bet you could just buy a silicon coupler and use that on your stock intake. Measure the MAF housing to be sure, but I think it's 3". Something like this: http://amzn.com/B004NYGSLE
The z tube I bought came with the couplers
Old Jul 9, 2014 | 10:43 AM
Lartytiejdke3's Avatar
A stillen one?
My stillen needed to be paired with OEM couplers as mentioned
Crazy hp #s now.
Old Jul 9, 2014 | 12:08 PM
LoSt180's Avatar
Was it used? The STILLEN ztube needs to reuse the G couplers. The 350Z OEM ztube has the couplers built into the one piece design.
Here's a comparison, of the TWO different things both called a "ztube," if anyone is confused:
STILLEN ztube:
350Z OEM ztube:
Old Jul 9, 2014 | 04:38 PM
dc2long's Avatar
Was it used? The STILLEN ztube needs to reuse the G couplers. The 350Z OEM ztube has the couplers built into the one piece design.]
You're right. The Stillen Ztube would need to be paired with the oem couplers which I need to replace. The OEM Ztube comes with the coupler attached to it.
I was really contemplating about picking up the Z1 tube because it comes with silicone couplers which I think is a better design and material. The OEM couplers look like they can tear easily if not put on correctly.
Anyways, I just purchased a used oem z tube from a member on this forum yesterday for a good price. Should be here Friday. Thank you for all your help!
Old Jul 9, 2014 | 05:22 PM
saywat?'s Avatar
jus buy a oem ztube used online/forums $50-60
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
