VDC: Off ?
Old Feb 15, 2005 | 05:02 PM
Klubbheads's Avatar
I span out of control one time slip light didnt come on. I had my vdc off though.
Old Feb 16, 2005 | 02:58 AM
Nickk6's Avatar
Well the reason I thought VDC instead of the LSD actually working is because I had the VDC turned off and after I completed the turn and looked down at the guage pod, I noticed the VDC was back on and I had never turned it on.
Old Feb 16, 2005 | 07:44 AM
cato's Avatar
SouthernComfort Moderator
We have two different systems here. The "Vehicle Dynamic Control" system (VDC) and
the "Traction Control System" (TCS). Turning off the VDC has no effect upon the TCS,
and I don't believe you can turn the TCS off.
Old Feb 16, 2005 | 12:51 PM
G35_coupe_6MT's Avatar
what are you supposed to feel when aided by the TCS?
Old Feb 16, 2005 | 02:40 PM
cato's Avatar
When you see the "slip" light come on, it's the TCS doing it's thing, not the VDC,
When you see the "VDC" light come on, VDC is in operation.
Old Feb 16, 2005 | 03:39 PM
doogie's Avatar
I've never seen a VDC light aside from the one that tells you VDC is disabled. The only lights I've seen are ABS and SLIP, right in the middle, and when I've been sliding and VDC kicks in to correct, it's still the "SLIP" light that illuminates. The same one that illuminates when power is cut when taking off too fast at a light or something.
Old Feb 17, 2005 | 08:15 AM
cato's Avatar
OK, then when the VDC jumps in it triggers the ABS.
Old Feb 17, 2005 | 09:59 PM
Klubbheads's Avatar
VDC on = slip light blinks when there is a loss of traction.
VDC off = no light comes on even when i span out of control
Old Feb 18, 2005 | 12:37 AM
DaveB's Avatar
You can turn the traction control completely off if you remove the ABS fuse under the hood.
Old Feb 18, 2005 | 02:23 AM
Kodeslinger's Avatar
traction control didn't do squat when i pulled a few donuts :P
tha_ape
Jul 21, 2015 01:15 PM
tha_ape
Jun 14, 2015 07:50 AM
tha_ape
Video Share
Jun 7, 2015 10:42 AM
kfreefall
Feb 18, 2006 08:38 AM
suprhulk
Feb 27, 2003 03:26 AM
