Slight engine miss at WOT
Old Sep 7, 2014 | 12:05 PM
3maxima's Avatar
When I am trying to pass on a two lane road or really hit it on an on-ramp I get a slight miss. If I ease up just a little it will smooth out. Otherwise it always runs great. Coil pack? Injector? I changed plugs (iridium) about a year ago.
Ideas?
Old Sep 20, 2014 | 11:10 AM
3maxima's Avatar
I find it hard to believe no one has an idea.
Old Sep 20, 2014 | 10:19 PM
markc's Avatar
No check engine light, I presume? Not going over red line either?
Old Sep 23, 2014 | 05:47 PM
maxxcool's Avatar
If your the mechanical type... pull the plugs. My misses were related to fouled plugs and very lean AFR.
new plugs and a oil catch can helped. but ultimately I needed a tune to go further. it is still early on for my tune results so I won't say the tune fixed it 100%.
Old Sep 27, 2014 | 09:45 PM
3maxima's Avatar
No check engine light, not going redline.
I could go ahead and change plugs again and give them a look over when I pull them.
Old Sep 29, 2014 | 10:11 AM
Bassman's Avatar
I had a similar problem with a 1976 VW. It needed a fuel filter change. The pressure to the injectors was too low at high RPM.
Old Sep 29, 2014 | 01:16 PM
Mustang5L5's Avatar
Pull your plugs soon after a few WOT runs. That will give you a better impression as to if you are running lean. If you idle or cruise around for a bit, the results will be skewed.
Old Oct 20, 2014 | 08:33 PM
BBPATHFINDER's Avatar
Leaky cam cover gaskets, leading to oily plugs will lead to a miss fire.
Old Oct 21, 2014 | 12:11 PM
maxxcool's Avatar
^ this along with the general nature of the PCV system to suck oil up. Did a catch can and so far my plugs have been much better off.
my previous set of plugs (before the catch can) were replaced by the oem dealer under a used warranty and they lasted all 2 months before having no-fire and severe ping issues in mid summer heat.
oil is your enemy for v35 blocks.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
tiguy99
Mar 1, 2016 11:42 AM
mjfenix
Jul 17, 2015 02:07 PM
