Small vibration while in Idle. Normal?
Old Sep 22, 2014 | 07:49 PM
ImJJames's Avatar
2003 160,000 miles
So when my car is on idle it hovers around 600-650 RPM. But I am noticing a weird vibration coming from engine bay. Its not a consistent vibration. Its more like a 1-2 thump type vibration every 1-2 seconds.
It is really hard to explain. Its not noticeable at all if you're not paying attention to it.
Old Sep 22, 2014 | 08:42 PM
Hatchman's Avatar
Check the motor mounts.
Old Sep 22, 2014 | 09:04 PM
ImJJames's Avatar
Thanks
Old Sep 23, 2014 | 02:21 PM
AARONHL's Avatar
Same here I think my manual transmission has been shot since 2008
Old Sep 23, 2014 | 03:19 PM
Mustang5L5's Avatar
Fuel dampener?
It is a common problem. Sounds like a semi-rythmic knocking.
Old Sep 23, 2014 | 03:31 PM
ImJJames's Avatar
Originally Posted by Mustang5L5
Fuel dampener?
Correct, but not knocking more like a thud.
Old Sep 23, 2014 | 04:00 PM
ScraggleRock's Avatar
Is it like the cars gonna stall? Like do the rpms dip?
Old Sep 23, 2014 | 11:05 PM
ImJJames's Avatar
Nope the RPM is completely stable does not feel like its going to stall at all.
Old Oct 7, 2014 | 10:35 AM
trodder's Avatar
I wonder if you have what I just recently started to experience. It almost sounds like a bad fan running at idle. When you lightly press the gas does the sound speed up with acceleration? Also does it do right after a cold start or more when the car warms up? Also if you put your ear by the front tires is it much more noticeable? That is what I have been experiencing and I have no clue what it is but would love to find out! If the radio is on you will probably never hear it but when just sitting quiet in the car you barely hear it and standing outside the car you don't hear it either unless you put your ear by the front wheel wells. For me it seems like the car has to run a bit before I hear it after a cold start.
Old Oct 8, 2014 | 06:04 PM
ImJJames's Avatar
Going to test these out later.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
G35xdriver04
Nov 7, 2015 08:31 PM
5150DS
Sep 26, 2015 07:47 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
