Just made the A/C in my new G35 the coldest I've ever felt.
Could be worse, the first "refrigerated air systems" used in meat coolers and air conditioning in early hotels had Ammonia as a refrigerant. Not pleasant when it leaks.
After doing some research about warm air from the A/C at idle I came across this thread and decided it would be an inexpensive fix. I was already planning to install a used Nismo bumper for my 03 sedan and changing out the fan motor would be ideal. Everything went together nicely and the A/C has been working a lot better. However, after a long drive and coming back into town with stop and go traffic with A/C on my temperature gauge notched up slight. I would say it got up to 70% not quite 3/4. A/C came off and temperature came back down. It has done this a few times already but only after a long drive. Would anyone like to share their thoughts on what might be the issue. Thanks for your time.
After checking both fans turn on. I never had a problem before with engine temperature while my AC blew warm and now its the opposite. I have cold air but a slight engine temp issue from time to time. Go figure.
Did you replace a fan? Make sure they're both spinning at the same speed. The bad one on the a/c side of my car would spin sometimes, but it would spin a little slower than the other fan. I could push the blades with a stick and make it spin back up, so I'm guessing it was going out intermittently while I was on the road and causing my car to overheat.
I replaced the fan motor. The fan control module, would that be the climate control panel on the center dash? I've had that refurbished when I was experiencing random radio/climate control issues. I may just put the old fan motor back on since I wasn't experiencing overheating issues with it.
Rehman2009
Jul 27, 2015 03:23 AM
laksjd84
Jul 24, 2015 05:12 PM
