G35 headlight problem
Hi
I have my g35x running 6k hids at night with stock ballast and I live in Canada so I need a drl module. But mine choked and died so now I haven't had my drls running for about three months now. But the other night when I was about to drive my hids come on of course but my passanger drl or the low beam like is always on now with the hids. It never was before and I don't think it's suppose too. Anyone had the same problem??
Thanks
Thanks
Check the drl module. Its a little black box mounted on the strut tower by the passenger headlight.
You can open it up by spreading the cover over the tabs. Its just a circuit board inside.
Mine was broken off the mount and hanging upside down.....thus full of water and it grenaded itself.
Maximas and altimas use the same box if you need to replace it.
I had to piece together 3 different modules....including replacing resistors and a couple diodes. Been workin for over a year.
$5 for two broken ones from a junkyard vs $350 from infiniti.
Good luck!
Good luck!
laksjd84
Jul 24, 2015 05:12 PM
