03 g35 pulled then slip and vdc light came on.
Old Dec 19, 2014 | 12:58 PM
jaycee92's Avatar
I was driving at about 45 mph then my car pulled for some reason and the slip and vdc off lights came on. What does this mean?
Old Dec 19, 2014 | 07:17 PM
JKL1031's Avatar
Boost kicked in..
Old Dec 20, 2014 | 12:16 PM
Gman56's Avatar
When they came on my 05X it was the cam senor on bank 1. Replaced it lights went out.hope that info helps you out!
Old Dec 23, 2014 | 08:22 AM
Mustang5L5's Avatar
Car pulled to side?
Have you pulled the wheels off and taken a look? If the light came on, and you felt a physical difference in how the car is driving, then I'd venture to say you have a mechanical issue somewhere.
I'd pull the wheels and inspect on the side that the car pulled to.
Old Dec 26, 2014 | 01:37 AM
majic's Avatar
When my slip and vdc came on, it was the yaw sensor (scanned with special tool that read bcm codes)
Dealer wanted $1200, ebay'd a used one for $40. Installed with battery disconnected and problem solved.
I only saw a couple dried coffee droplets on the old sensor... the sensor is right below the cup holder, and if you spill too much there are 2 side holes (under cup insert) that drains above it... weird.
Hasanbaloch
Feb 29, 2024 08:45 PM
Mry
Mar 3, 2023 01:03 AM
laksjd84
Jul 24, 2015 05:12 PM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
