What did I do wrong?
What type of low beams did you install? I installed 8000k low beams my high beams seemed dim. I figured out since l switched to 8000k it made the high beams seem yellow and dim. The low are so bright.the high seemed dim and yellow. Maybe you are experiencing the same as l did.
I used 6000 replacement so I don't think it is weak voltage but my friend also told me to check ground wire since any interruption would cause it to dim. Just have to get the motivation to take it apart today to check. Will report my findings. Yes I used original ballasts and only one side is dim.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Visionnn
Oct 3, 2015 05:16 AM
Learned Hand
Oct 1, 2015 09:02 AM
