Replacing OEM bushins with new OEM bushings on rear suspension mount
Old Dec 31, 2014 | 09:43 PM
munkle's Avatar
2006 G35X
I need to remove the OEM bushing, and I intend to replace it with a new OEM-type bushing. This is the bushing mounted into the rear knuckle to which the rear shocks connect on their bottom end. HERE is the bushing.
Can a bushing like this be removed while the knuckle is still on the car with the "threaded bolt" method? I have seen others talk of removing this same bushing with the rental ball joint presses available from Auto Zone and others (these are essentially just a C-clamp). Here is a picture of the type of "threaded rod" setup I am asking about. Anyone have any experience with this? This bushing is only about 1.25" in diameter, and the car has mostly been driven in non-coastal Southern conditions. The rubber is completely destroyed after 178,000 miles.
Also, should I expect to be able to install the new bushing using this same method providing I clean the mating surfaces well, and possibly use dish soap or a powdered graphite lubricant?
Old Dec 31, 2014 | 09:45 PM
munkle's Avatar
DIY tool for replacing OEM bushins with new OEM bushings on rear suspension mount
2006 G35X
Old Jan 2, 2015 | 12:23 PM
Blue Dream's Avatar
I drove ttrank's car solo
Please only make 1 thread on the same topic, thanks.
rezendvous420
May 31, 2020 01:26 PM
itschuckster
Jul 25, 2015 08:07 AM
cyrus32
Jul 18, 2015 06:22 PM
