g35 sedan first transmission fluid change
Old Jan 16, 2015 | 05:55 AM
arthurarenas's Avatar
Hi i have a 2005 g35 sedan it has about 114k miles and i wanted to know if i should do a complete flush or the simple drain and fill...i heard if you do the full flush it will harm the transmission. To be honest i dont even think the car has even had its first transmission oil change. I look at the fluid is brownish and smells burnt i knew something was wrong gotta fix her up and i need your help.
Also is there a difference between matic j or matic s, or should i just stick to matic j. But mainly let me know if you think a flush would be better off or if a simple drain and fill would be safer thanks.
Old Jan 20, 2015 | 12:03 AM
Caconman424's Avatar
At the dealership I work at, we recommend a drain and fill every 30k and a flush every 60k. I would recommend doing a flush so the trans will run fresh clean new oil.
Im only a light duty, so I cant say for sure that if adding new fluid to a trans thats gone that long without service is detrimental, but logic tells me that you would be better off running new fluid.
Thats what I would recommend to you if you brought your vehicle into me. I can verify with a journey man this week if your concern is validated if you would like.
As for fluid, I cant say i know off the top of my head as I usually let our parts dept. handle that. But again, im sure i could find out. Just let me know.
Old Jan 20, 2015 | 07:33 PM
saywat?'s Avatar
^ the dealership u work at never mentioned Nissan discouraging dealers from doing flushes?
Old Jan 20, 2015 | 08:31 PM
The Fixer's Avatar
Matic S is the replacement for Matic J, which was discontinued. If you're unsure of it's history, you'd probably be better off doing a drain and fill (4 quarts when you drain it at the plug on the pan), and then do another drain/fill in a few thousand miles.
Old Jan 21, 2015 | 03:06 AM
gq916's Avatar
You should do a full flush. I did a full flush at 66k miles from the dealer about 3 years ago. My oil was very dirty at the time. Should have done a drain and fill at 30k miles.
As for the oil, J-matic is what came the factory. J matic is non-synthetic and S-Matic is synthetic. I had a choice and went with J-Matic since S-Matic(synthetic) would have too much slip and you don't want that with most transmissions. They say J-Matic is discountinued but dealers still have it in their shops.
Old Jan 21, 2015 | 02:49 PM
Spartan268's Avatar
If it's been almost 100k miles without anything done to it.
Do a drain for sure.
There's been reports that doing a flush (Especially on higher mileage transmissions that havent had anything done to it yet) craps out the tranny.
From another thread:
Originally Posted by ACE420
It's perfectly fine if you do the drain/fill technique...it's only a problem to have a FLUSH done on your transmission. This is due to high mileage In the transmission, you can "shock" your transmission and ruin a lot! Basically when you don't flush your transmission for many many miles the build up it forms on the inside is used as a type of grip for the machine to work properly.. So if you FLUSH it will clean most of this build up off and it will cause the transmission to slip a lot resulting in problems...just play it safe a drain and fill..drain a few quarts and fill with same amount of new fluid, drive for a few thousand miles and repeat until the liquid you see when draining is newish in color. Also don't forget to look for metal shavings and stuff when initially draining, this is a sign something more significant is happening to your transmission that needs to be dealt with
NemesisGee
Aug 11, 2015 07:10 PM
teamghost
Jul 28, 2015 04:52 PM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
newbdriver01
Jul 15, 2015 06:10 PM
