need help with this burn smell
Old May 27, 2015 | 08:42 PM
dust180's Avatar
check around valve covers for leaky valve cover gaskets, next check your oil cooler seal behind your oil filter at the block (known for leaking) then after that also check where your trans bolts to your engine, my trans's pump seal was leaking pretty bad and at low rpms there wasnt enough pressure to keep 5th gear properly engaged and burned up my 5th gear! When I finally replaced the trans the smell went away with it. Any fluid there could be oil (rear main leaking) or trans fluid (pump seal leaking)
Blue Dream
Dec 5, 2015 10:56 AM
prinny
Nov 22, 2015 11:07 PM
Vqalexisz
Oct 14, 2015 12:48 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Learned Hand
Oct 1, 2015 09:02 AM
