New to Infiniti! Hi! and please help!!
Feb 27, 2015 | 05:16 AM
What is crc
Reply 0
Feb 27, 2015 | 05:25 AM
Hopefully hes talking about Lectramotive or whatever its called. Its an electrical contact cleaner made by CRC. They also make Brakleen and stuff.
Reply 0
Feb 27, 2015 | 08:51 AM
Yeah,crc MAF cleaner, ok so i just thought about something, when I got the car someone had allready put in the metra kit and an aftermarket stereo, ok so thats a seperate circuit board correct? If so then something is making my climate controls blip and come on and off in the morning as if it was the original radio
Reply 0
Feb 27, 2015 | 11:19 AM
It's my understanding that if you disconnect the MAF sensor with the car running or if you turn the key to "on" while it is disconnected, you must go thru a "re-learn" procedure. Don't ask me what it is, I just remember reading that hear somewhere.
BTW: ONLY use a cleaner for MAF! You can destroy them by using "brake cleaners" or "contact cleaners" .
Reply 0
Feb 27, 2015 | 03:01 PM
yeah, it was mass air flow cleaner, and I did in fact so a relearn.... not 100% on if it took but when it does run right , it idles and runs right
Reply 0
Feb 27, 2015 | 05:57 PM
Quote: If your gas cap isn't tight it will throw the CEL on. How did you clean your maf sensor. The reason I say check your battery, I recently had a problem my car wouldn't start on very cold days and on days where the temp was above 20 degrees it would. My battery had been in the car for 10 years.
WOW! 10 years is a helluva long time for a battery in a G! I have to change mine every 30-36 months, which seems to be about the norm for the G.
Reply 0
Feb 28, 2015 | 10:12 AM
I got about the same, even with an Optima Red Top. 3-4 years max.
Reply 0
Feb 28, 2015 | 10:53 AM
I bought my car in 2013 on December 13th on a Friday. So much for Friday the 13th being a bad luck day (I never believed Friday the 13th being bad luck anyway). My car was 8 years young when I bought it and after looking it over I could tell the battery had never been changed. The previous owner traded it in for a corvette and it had just over 25,000 miles when I bought it.
I've had it for 2 beautiful years now and have done some mods with more to come. I noticed the battery worked harder to start my car but, upon checking the volts everything looked good. Twice it wouldn't start and I needed a jump (once when I got off from work) after changing the battery everything is good. I've driven many cars from Ferraris to Porsches, Maseratis (which I'll be owning shortly) but, the first gen G coupes have a body that is NEVER going out of style, it will forever be beautiful and the right mods will only make it more beautiful. I pity those that get rid of their G only to regret the decision. However, new owners bring new ideas some good and some bad. What I love most about my coupe is one, it gives me what I need and not all those unnecessary things I don't, two, it's a drivers car. The harder you drive it, the better it gets. Three, with the right mods, it can hold its own against cars costing much more and still prevail. Just like so many others I enjoy driving it everyday. Long live the G.
Reply 0
Mar 1, 2015 | 11:40 AM
Ok so i think i have almost narrowed it down... Last 2 days did fine! No cel no vdc no slip... Rained last night..... Guess what!? Limp again and i took battery cover off and there was some water down on the ipdm box and on some wires........
Reply 0
