New G35 owner
Old Feb 18, 2005 | 02:34 AM
hyetexa2001's Avatar
Question New G35 owner
Hi my name is John and i just got a new g35 sedan yesterday. I had a question about the stick shift i got the one with aoutmatic transmition with the auto clutch manual dont know the real name its my first car and never used stick shify. I tried it out today ut whe i got to a turn the car sortha shook like the transmission had a prob or something was i suppoed to shift before turning or something can someone tell me exactly how to use stick shift. What rpm to shift, what speed, before or after turning , etc i would really appreciate it if someonecould help ill try to post a pic l8r on it is a black sedan with stone gray or whatever it is called interior
Old Feb 18, 2005 | 03:16 AM
g35girl's Avatar
Unimaginative, Indecisive User
your interior is called "graphite." as for learning how to use a stick shift, you'll need to learn on a real manual transmission car, not your G, since it isn't a true manual, but a "manumatic." so maybe you should keep your car in auto for now. good luck.
Old Feb 18, 2005 | 03:23 AM
Smile
thanks for the tip. I am going to keep the car on auti but i am gonna try to learn how to use the manumatic. Im jsut afraid im gonna mess it up lol.
thanks again
Old Feb 18, 2005 | 03:39 AM
skeleton_cru's Avatar
Sedan
Keep the shifter on Auto until you get used to your car. Fortunately the G has a rev limiter which will help protect your car from you.
Old Feb 18, 2005 | 03:42 AM
Unhappy
ya i heard about the limiter but why does the car shake when i turn it only happens when its on manual is it some kind of break in thing. can u tell me what rpm is good to shift with. i dont know what to do when im on 2nd or more gear and im slowing down do i have to shift down or shouldi just accellerate. Can someone plz tell me
Old Feb 18, 2005 | 03:47 AM
Jafri91's Avatar
If you are a new owner dont rev past 4,000 rpm till you hit 1,200 miles, .... break in period
Old Feb 18, 2005 | 08:45 AM
mikeee2's Avatar
If you never drove manual before you might get confuse using manumatic. For 05's it starts at 1, just shift at 3,000rpm for now to a higher gear. When you brake it drops the gears for you. The shaking might be you went to a high rpm and then just let go of the gas before you turn. In you are on "D" it shifts to a higher gear but on manumatic it stays on the gear when you turn. You are better off understanding how the whole rpm thing works before you use the manumatic mode. I used it all the time because I used to drive stick shift but you do have to constantly look at the dash just to make sure you are on the right gear and have to listen to engine sound just so you know when to shift.
Old Feb 18, 2005 | 10:02 AM
lawboy05's Avatar
CONGRATS on your new G!!
As for you issue regarding the "manumatic," I think you should hold out on using it until you know how to use it. I realize this sounds a bit like a Catch-22. However, I really doubt anyone can "tell" you how to actually use the manumatic through this venue. Perhaps a trip to the dealer would be beneficial. Allow a knowledegable salesperson to show you how to utilize this feature. Otherwise, I'm sure you could do some damage to your car.
Old Feb 18, 2005 | 12:00 PM
G35keg's Avatar
Actually lawboy05 has a good idea, go back to your dealership and ask if someone there could give you a few lessons on how to use the manual mode.... But here's some tips..
Basicaly you will want to shift between 3000-4000 rpms when driving normal, this should give you a nice smooth shift between gears.... Also when driving the manual mode, you do not need to let off the gas when shifting, just keep your foot into it when you shift, otherwise you will get a jerky sensation...
only thing I can guess that would cause the car to be jerky taking corners in manual mode is your keeping the car in a low gear and the RPM's are high as you go around the corner, when the RPM's are high the car is extreamly sensative to throttle input and this would cause your car to jerk/shake if you didn't have a steady foot on the throttle. Next time you go around a corner make sure the RPM's are around 2000-3000 and it should be smoother...
Old Feb 18, 2005 | 03:14 PM
thanks for all the info guys ill still try to learn how to use it but when i asked the dealer salesman they didnt tell us. But where very nice people. The people at one of the nissan places were complete *******s they didnt give us any offer on anything they didnt even explane anything good. well thanks again everyone
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
vstypicals
Jul 20, 2015 10:55 PM
Chattzx
Jul 17, 2015 11:23 AM
