road noise?
Old Mar 19, 2015 | 08:48 PM
micahd'sG35X's Avatar
road noise?
I have a 04 g35x. only mods so far is a ztube and knn panel filter. the thing is i have really bad road noise coming from the front driver side. i put new good years all around and the noise persists it starts at low speeds. below 20 and continues to get louder the faster i go. rattles the whole damn car. if anyone has a CLUE as to what's up lemmeknow. btw I'm no noob to cars or nissan/infiniti, feel like I'm chasing
Old Mar 19, 2015 | 09:44 PM
Commuter's Avatar
Have your wheel bearings checked out. Sounds similar to what I was experiencing - changed out both front wheel bearing and the noise went away.
Old Mar 19, 2015 | 10:29 PM
gary c's Avatar
Two possibilities on the noise you're describing, check your front tires for wear on the inside 1/4s. At one point the noise got so bad before I installed a camber kit (bought new tires) I couldn't turn up my tunes loud enough. Wheel bearings are another possibility but you should also hear grinding noises too. Both are easy to check...Gary
Old Mar 19, 2015 | 10:32 PM
Urbanengineer's Avatar
New good years Gary.
Op, raise the wheel up with the provided jack and rock the whee from top and bottom (hand on each part of the tire mentioned). If there is "play" then you likely need new wheel bearings.
Old Mar 20, 2015 | 11:31 PM
SIKKI's Avatar
Exclamation
Ran you problem through a friend of mine who is a Infiniti Tech @ Orr Infiniti in Shreveport, LA. He has seen this a few times and it is the bearings.
Old Mar 20, 2015 | 11:41 PM
Awesome thanks for the input. payday ill put new hubs and bearings up front.
Old Mar 21, 2015 | 01:27 AM
gary c's Avatar
Damn I missed good years, had he posted Good Years I might have seen it! I quit using those **** tires when one left me stranded 70 miles from my front door! Ever try driving 60 max mph on the interstate 5 at midnight running a f'n donut tire? Check the wheel bearings...Gary
Old Mar 25, 2015 | 07:04 PM
Skeeter SS's Avatar
Probably wheel bearing. I'd reuse the old hub they tend to hold up. Bearing not so much.
Old Mar 31, 2015 | 10:44 PM
I got the new bearing in yesterday. not the easiest thing to remove, aluminium and steel don't mix to to well. it was siezed up like no other. even with a mac tool hub tamer set and lots of pb blaster. cleand it up put the new one in pressed in the hub. wow. its like a whole new car. thanks for most of the input.
Old Apr 1, 2015 | 09:11 AM
Mustang5L5's Avatar
May not be that obvious. When my 3 wheel bearings failed, there was no play at all.
In order to diagnose, i had to take the wheel and rotor off and physically grab the hub and turn it. Only then could i feel the roughness.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
alinero718
Sep 27, 2015 09:35 PM
