Alarm rings EVERYtime getting in or out, Reprogram??
Old Jun 15, 2015 | 01:12 AM
ranhood's Avatar
Gang!! So, everytime I get in or out of my car, the chirping alarm (not horn) rings for a few seconds as if the lights were or ignition is left on, etc. Some background... i just got crunched on driver's side, both front, rear doors replaced. Since getting from body shop, after 2 weeks... this in my new "feature!" Is there a need reprogram or reset the system? I imagine the batter was disconnected the entire time as doors were off it. If I could ask for some help - info???!! Thanks much!!! -r (coincidentally... seems like my starter is dead. car only starts sometimes!) coincidence, right??!!
Old Jun 15, 2015 | 09:39 AM
Mustang5L5's Avatar
Is this an intelligent key system, or a standard key?
Is it the fast pace, really quick "beep-beep-beep....." that oyu hear if you try to lock a door and it's still open?
Old Jun 15, 2015 | 09:59 AM
ranhood's Avatar
It's the intel key system and yes, it is the fast pace beep-beep. Only does it when the fob is inside the car. So, I get in with the fob, close the door and "beep-beep" quick "warning" type beeping. If I take my fob with me, out of car, no beep warning. (most often i just leave the fob in the car... pretty unlikely someone randomly jumps in my car to steal).
Doors lock correctly - alarm seem to be setting correctly. Wondering if odd setting is causing issue with car not wanting to start periodically??! Tks MTang!!!
Old Jun 18, 2015 | 08:20 PM
ranhood's Avatar
Well, popped in a new starter and Shazam!! Did the trick. (at least for not turning over) The damned warning alarm still goes off everytime the door is shut with FOB inside.
Old Jun 23, 2015 | 10:07 AM
ranhood's Avatar
Well is was NOT the starter Back to same old non starting crap-0-la!!! Put in new starter and worked for 3 - 4 days NO probs. Except the rapid warning BEEPBeepBEEP. Battery good, clean. Seems like a "lock-out" type setting or mode. Do the G's have that? Recognizes the intel-key. All lights up, just nothing when attempt to turn over. Any help would be so great!!! Tks gang!!
Old Jul 16, 2015 | 04:21 PM
Matthaios's Avatar
I'm having the same issue with the beeping as well. Have you figured it out yet? I've had this problem for the last year now and still have been unable to figure out what's going on.
Old Jul 16, 2015 | 04:53 PM
ranhood's Avatar
No, nothing yet. Spoke to my dear dealer service folks twice. They suggested to replace battery in FOB. So, yeah... I played along but of course, didn't change a thing. I've recently discovered that the sensor in the trunk (which prevents you from locking key in trunk) no longer works. Certainly related. I'm running to dealer in a couple weeks. I'll post what I find out. Tks!
Old Nov 18, 2015 | 01:38 AM
MrGaryZ's Avatar
Seems like I have the same problem. Did you find any useful information from your dealer?
Old Nov 18, 2015 | 03:23 PM
ranhood's Avatar
Nothing new. Dealer didn't know. Service Advisor stated they didn't look into it much. They replaced relay/switch in the IPDM for starter problem. So without running some sort of expensive "diagnostic test" they didn't attempt to offer any information or help. It's only associated with driver's door. If I open a rear door, close driver's door first then rear door... no rapid beeping. Or, when getting in car, if another door is open when I close driver's door, again no beeping. So stupid! Let us know what you find out!!!
g.spot
May 9, 2016 10:54 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Danielek
Sep 18, 2015 12:16 PM
Chadwick Arnold
Sep 9, 2015 02:59 PM
UT G35
Sep 3, 2015 03:58 PM
