What the frick is the sedan parking light
Old Jun 22, 2015 | 12:13 PM
Mustang5L5's Avatar
Then I would defer back to the bulbs.
Absolutely 100% sure that the bulbs (which are OEM halogen) are all illuminating when you use the turn signal and hazards?
Also, what year is this? I only ask because the 03-04's use a single filament bulb for the turn signal, whule the 05-06 use dual filament. Maybe that has something to do with it.
If so, I might convince myself to swap bulbs to the other side and see if the problem changes sd
Old Jun 22, 2015 | 12:20 PM
05_SkylineSedan's Avatar
20 Year Member
Originally Posted by Tyke420
^ could it possibly be a clock spring issue...? Cause right around the same time this happened my volume/seek controls went out on my steering wheel ... I really don't want to put resistors in..
By "clock spring" you must be referring to the "spiral cable" behind the steering wheel? Nothing to do with turn indicators. The spiral cable also operates your horn, cruise control buttons, phone controls, and driver airbag. So if it completely failed the SRS system would be flashing lights at you and throwing error codes.
Another idea ... sometimes bulbs from different manufacturers or of incorrect wattage can throw things out of balance. Check your 4-way flashers again to make sure all corners are blinking and try to determine if they are the same brightness.
Just a guess...
What year is your car so we can look up the OEM bulb?
Old Jun 22, 2015 | 10:04 PM
ㄴㅇㅇㄱ™ ninja's Avatar
Veteran: Navy
Veteran: Army
Kinetix V+,Z1UpperArms+HFC,FujitaIntake,Nismokit,BCCoils,HKSexh,G37rims,CFtrunk,nWpTB,SPCarms
Originally Posted by Spartan268
Do you have any pictures of it on at night?
I creeped your garage and found nothing
I'll take one this Thursday night at an National G Club meet depending on how dark it gets or when I get home
Old Jun 23, 2015 | 12:36 PM
20 Year Member
Oh duh, just saw your signature. '04 and '04.5 have 21w single-filament incandescent turn signal lamps, front is amber and rear is clear. I'm sure you know that already... Hyperblink should only happen if one is burned out, not the right wattage, or if the circuit is incorrectly "loaded" with an LED lamp with no resistor.
Old Jun 23, 2015 | 04:02 PM
Tyke420's Avatar
Well mine is an 05.. I'll check my four ways when I return home again. Thanks for the input. I was also thinking maybe a light is getting ready to go out. I don't drive my car a whole a lot a don't use the signal that is hyper blinking consistently.
Old Jun 24, 2015 | 12:30 AM
20 Year Member
Sorry, getting my posts crossed.....
Tyke420, on your '05 the front turn signal and parking lamp are the same two-filiment bulb 21/5w. The rears are single filament 21w bulbs. A couple examples...
Attached Thumbnails What the frick is the sedan parking light-21-5.jpg   What the frick is the sedan parking light-21.jpg
Old Jun 24, 2015 | 03:03 AM
Tyke420's Avatar
Thanks for that, I just realized, the previous owner did put two LED strips in the front headlights.... Nothing dramatic, but I just realized that. I think there LED's anyway, they're barely noticable though... I'll ask him when I get a chance... I'm assuming that's where my problem is now that I think of it... They were working fine for quite sometime though after I bought the car.... Who knows, I'll ask him some questions, he's a good guy......
Old Jun 24, 2015 | 11:41 AM
Mustang5L5's Avatar
Depending on how they are wired, that might be your cause.
Mry
Mar 3, 2023 01:03 AM
Wayne9011
Aug 17, 2015 01:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
Wayne9011
Jul 27, 2015 11:25 AM
tiguy99
Jul 26, 2015 01:39 PM
