No start - No Crank - except if engine is Cool??
Old Jul 9, 2015 | 02:02 PM
ranhood's Avatar
Hey gang... help!! I replaced starter (remanu) and got a new battery. (old one was under warranty but I think it was fine). G won't turn over if car has been driven for 20 - 30 mins. Once it cools down - cranks right over?!! When no crank, I did a voltage drop test on starter post with other lead grounded on starter case. Attempted to start - no voltage change at all! Volt meter read 12.65V before turning ignition and 12.65V when turning ignition. How do I test the lead that comes from the ignition at the starter?? Everything lights up, no loss of voltage when attempting to crank at battery and post clamps. Engine has never died... just won't crank if driven for bit - takes 30 mins or more to cool down. Killing me!!! Please bail me out of a dealership trip!! Thank you, thank you!!
Old Jul 10, 2015 | 02:16 PM
ranhood's Avatar
bueller bueller anyone
Old Jul 10, 2015 | 02:53 PM
Almightyone's Avatar
The car won't spin over at all when it's warm?
Old Jul 10, 2015 | 02:59 PM
ranhood's Avatar
Allmite1 I appreciate the reply but yeah... wouldn't be that. Tks for playing though!! =)
Old Jul 10, 2015 | 03:03 PM
ranhood's Avatar
Nope. No crank at all. Everything lights up, hear fuel pressurize, everything seems great but then when turn ignition switch to start... nothing, nada, pure quietness. =(. Again, if car has been sitting for a few hours, it's good to go but if drive for 30mins or longer - turn off and then won't crank up. damndest thing!!
Old Aug 6, 2015 | 01:15 PM
ranhood's Avatar
So if anyone here cares... Problem solved!! Turns out it was relay in the IPDM. Put in new relay and we're off and running!!! I have to give props to the dealership... correct diagnosis - pleasant, washed my car =) tks for all input.
Old Aug 6, 2015 | 02:17 PM
yosip1115's Avatar
Thank you for updating results. Never heard of that problem. Good to know.
chinee
Jun 10, 2024 07:48 PM
andyg35c1
Aug 29, 2015 03:37 PM
chinee
Aug 8, 2015 10:11 AM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
