How to go about lowering my 05 X
Old Sep 9, 2015 | 03:17 PM
yosip1115's Avatar
Originally Posted by Mustang5L5
How much driving through the snow do you plan on doing?
These cars are pretty good in the snow with AWD. but lowering won't help. I drove though a ton of deep snow with mine and the only time I had problems are when ground clearance was an issue. I got hung up trying to break through a small "plow dam" at the end of the driveway and had to break out the shovel.
Main reason I never lowered my car was because I did so much driving in the snow.
It's so much fun blasting through snow at stock ride height with AWD!
Old Sep 24, 2015 | 11:16 AM
EasySausage's Avatar
well i used to drive a mustang in the snow so I'm not worried about the snow i don't care if my car is bad in the snow. i want to lower my car enough just so the wheel gap is gone. I'm planning on getting with 19 or 20 inch wheels on my car soon and i don't think that wheels will look good if the car isn't lowered a little bit to get the wheel gap gone, just my opinion. I still have no idea why you shouldn't lower an AWD car but i trust that these guys know what they are talking about so now I'm kinda scared to lower my car even a little bit. i literally just want that wheel gap gone when i have 19 or 20 inch wheels on the car.
Old Sep 24, 2015 | 12:05 PM
yosip1115's Avatar
Lowering it too much will cause extremely accelerated wear on the bushings and Cv axle boots. Lowering it a bit will cause premature but not extreme wear on the bushings.
It won't take much to fill the wheel gap, I think you'll be happy with a mild drop, coilovers or springs will work. Camber kit is necessary in rear, compression rod bushings, the rear should be ok bushing wise. You're going to chew through tires. I wouldn't want to chew through 20" tires, screw that!!!
Old Sep 24, 2015 | 01:00 PM
Lartytiejdke3's Avatar
well i used to drive a mustang in the snow so I'm not worried about the snow.
hell yeah
Old Sep 24, 2015 | 01:06 PM
VenomGT9's Avatar
Great contribution there
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
