Is it the entire compression rod or just the bushing?
Old Nov 24, 2015 | 11:13 AM
jdubin94's Avatar
Losing my mind with front end creaking.
I'm hearing a lot of creaks and squeaks when I go over driveways or slight changes in elevation. After what I've read, it turns out this is probably due to the compression rods, but not necessarily the compression rods, rather just the bushing. I want to know what to tell the shop to replace. What do you guys think it is?
Old Nov 24, 2015 | 02:05 PM
VenomGT9's Avatar
Replace with poly bushings if possible.
Also check other bushings in the area along with the sway bar links and bushings...these make creaks when needing grease.
Old Nov 24, 2015 | 03:31 PM
Mustang5L5's Avatar
It's prob the bushings.
Bushings are cheaper than rods, but rods are easier to replace (for obvious reasons). Which route you go is entirely up to you.
Old Dec 1, 2015 | 08:09 PM
saywat?'s Avatar
i went with aftermarket rods for ease and lifetime warranty but u can buy oem bushings only $50 or so
Old Dec 13, 2015 | 02:37 PM
bocatrip's Avatar
If you would like to get the complete picture on your compression rods, try this link I started a many years ago. Be prepared to do a lot of reading. https://g35driver.com/forums/brakes-...otal-crap.html
Old Jan 17, 2016 | 09:45 AM
Siciliang35's Avatar
Link not working
06G35newbie
Aug 11, 2020 04:48 PM
guod
Jan 13, 2016 07:54 PM
35reilly
Forced Induction
Nov 11, 2015 08:56 AM
Fire0nic3
Nov 8, 2015 10:35 PM
Albanian122
Oct 29, 2015 11:11 PM
