Power Steering Fluid
Old Feb 24, 2016 | 12:30 PM
IllaNoizeTV's Avatar
Okay guys, I just need to top off my power steering fluid and I'm confused as to what do I use. I seen here on the forum that you guys use Mobil 1 ATF? But why use automatic fluid for power steering? I've also seen on here to use the genuine Nissan power steering fluid. So would this work for our cars or is there a specific type of Nissan power steering fluid?:
Amazon.com: Genuine Nissan Fluid 999MP-AG000P Power Steering Fluid - 12 oz.: Automotive Amazon.com: Genuine Nissan Fluid 999MP-AG000P Power Steering Fluid - 12 oz.: Automotive
Old Feb 24, 2016 | 12:40 PM
Albanian122's Avatar
Yup, that works I purchased that about a month ago from Amazon. You only really need one bottle I made the mistake of buying two. You can change out the old fluid and replace it with that entire bottle.
Old Feb 24, 2016 | 12:43 PM
Thanks a bunch!
Old Feb 24, 2016 | 06:28 PM
5150DS's Avatar
I replace power steering fluid every oil change. I use a bulb syringe/turkey baster to suction the fluid from the reservoir. I then replace with new fluid to the cold fill line. You use atf because an automatic transmission is a hydraulic pump and so is the power steering system. I use Valvoline maxlife in mine. 211k and no leaks.
Old Feb 24, 2016 | 07:14 PM
Thanks 515. 211k miles is impressive! I'll replace the power steering fluid next oil change.
Old Feb 25, 2016 | 09:42 AM
Mustang5L5's Avatar
I've used Mobil 1 ATF exclusively since new. 170K miles no issues with steering
Jiggs1219
Feb 25, 2016 08:30 AM
Siciliang35
Feb 23, 2016 09:47 AM
Kingppoppy
Feb 19, 2016 11:28 PM
Bean_VQ35DE
Feb 19, 2016 08:44 PM
PTG
Feb 19, 2016 08:46 AM
