Shaking Issue
Old Mar 15, 2016 | 12:29 PM
JayVQ's Avatar
Yes I do. I have driven with and without the hubcentric rings and there is no difference in this behavior. T
Old Mar 15, 2016 | 02:13 PM
coffeysm's Avatar
Maybe a warped rotor, bent wheel (but you said they balanced fine, so probably not), and how about your CV joints inner/outer and/or the axle itself?
Check the replaced caliper again as well. I replaced one and the reman went bad about a year later and I had to get another one.
Old Mar 15, 2016 | 04:14 PM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by infinitidude
I have been with Infiniti for 11 years now and I have never replaced any bushings in the rear for a shaking/vibration issue.
I second that. Not unless you have some aftermarket arms installed there.
My SPL camber arms needed bushings replaced. Stock don't.
To check your brake calipers. Get on the freeway and go up to vibrating speed. Then come to a stop using transmission braking rather than brake pedal. Once you stopped check the temperature of each rotor. If one is significantly hotter than others, you'll know if calipers are dragging on that side.
Also, what brand of tires are you using, have they been replaced recently when you balanced them? Could be defect in the tire that causes it to wobble or shake at speed.
jbmw002
Nov 28, 2016 10:57 AM
Tylko Kazik
Mar 10, 2016 08:53 AM
Jgonzalez
Mar 3, 2016 12:20 AM
nicoG35
Feb 27, 2016 05:20 PM
nicoG35
Feb 26, 2016 04:55 PM
