automatic transmission fluid????
Old Apr 19, 2016 | 11:18 PM
5150DS's Avatar
Originally Posted by IllaNoizeTV
Thanks bro. Sounds like alot of work and I work 6 days a week, the day I have off I use it to rest and relax so im prolly gonna take it some where and do a complete flush eventually.
I highly suggest a drain and fill. A flush can cause problems. Have a mechanic do the drain and fill if you dont want to do it yourself. Honestly, it takes 15 minutes. No harder than changing your engine oil.
Old Apr 20, 2016 | 09:41 AM
Mustang5L5's Avatar
If anything I think doing a drain/fill is easier than an oil change.
No filter to swap out or undershield to remove
Just make sure you have a funnel that will fit the dipstick tube for the trans
Old Apr 20, 2016 | 11:15 AM
IllaNoizeTV's Avatar
Fineeeee... I'll drain/fill it. Do I drain the whole thing or only 3 quarts every time I do an oil change?
Old Apr 20, 2016 | 11:30 AM
coffeysm's Avatar
You just pull the transmission plug out and let it drain. BUT, make sure you put it in something you can measure first and do it when it's COLD. Then fill in the same amount you took out.
Old Apr 20, 2016 | 06:51 PM
5150DS's Avatar
Agreed, I drain straight into HDX buckets from Home Depot that have measuring marks on them. Putting back in the same amount you take out is easier this way.
http://m.homedepot.com/p/HDX-10-qt-Natural-Multi-Mix-Container-3-Pack-210217/204303499
Old Apr 20, 2016 | 06:53 PM
Indecisive's Avatar
oh damn thats genius. I'm always putting it in a mobil 1 oil jug that has a slightly translucent area on the side with marks but it's not always clear if I go over whats on the jug.
Old Apr 20, 2016 | 07:43 PM
coffeysm's Avatar
I was using an old clear ice tea pitcher. I do like the Home Depot buckets idea a lot better though! Thanks 5150DS.
Old Apr 21, 2016 | 12:59 PM
Mustang5L5's Avatar
Mine is always ~ 4 quarts.
After you get it done, you'll agree that it's pretty easy.
I forget the size of the trans pan plug. I think it's either 17mm or 19mm.
You'll need a 10mm on an extension to reach the bolt holding the dipstick tube in.
Old Apr 21, 2016 | 01:31 PM
Fire0nic3's Avatar
When i do it, I just do a drain and fill from the drain plug. I get 4 quarts out.
If you want to get another 1.5 quarts out, you can disconnect the transmission cooler hose return line and let it drain into a bucket. I always do this on top of draining it from the drain plug.
Old Apr 21, 2016 | 05:20 PM
Thank you everyone. You guys rock! I spotted this g35 yesterday. Super clean. P.s. I know my window is dirty and the pic is crap. Lol.
Old Mar 6, 2020 | 01:01 AM
Jonah Urban's Avatar
2007 g35x
Help
Originally Posted by Indecisive
I did this for my first round of drain and fill. Then I found their synthetic stuff and i'm using that now.
Castrol TRANSMAX™ FULL SYNTHETIC MULTI-VEHICLE
and here's the datasheet showing that it is spec'ed for JASO 1A
Data Sheet
how has this stuff been for you? Just got Castro’s transmax in my 07 g35x with 225,000km
Old Mar 6, 2020 | 01:05 AM
2007 g35x
Help
Transmissions generate lots of heat. Heat will break down the oil's ability to lubricate properly and then your clutch packs will wear down and lose material. When your clutch packs lose material they start slipping and don't become effective at transferring the work from the engine to the wheels.
The danger comes when you don't change fluid regularly. The clutch material will actually become suspended in the fluid and that will keep the transmission from slipping. So, because the suspended clutch material is whats keeping the transmission working properly when you replace the fluid with new clean fluid, the transmission is now slipping and shitty. This is what causes the myth of transmission fluid changes break your transmission.
Flushes take this a step further and replace ALL the fluid but it also usually puts some pressure in the system, or detergents or reverses the flow, so this will dislodge the material and it will now go into other areas of your transmission and make things worse. Generally a flush with a machine using detergents isn't advised. I'm pretty sure a Nissan transmission flush doesn't have any detergents though, just fluid.
so after all that...regularly changing your fluid is recommended, just like motor oil changes. However if the fluid has never been changed and it's a high mileage car, the transmission may be barely holding itself together.
what do u consider high mileage I just changed my with 224,000km 07 g35x automatic , I had a problem with the valve body so I had to change the oil
Old Mar 6, 2020 | 10:40 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Transmission fluid drain/fill interval is 30k miles, neglect at your own peril. You will never cause damage to the transmission by doing a drain/fill regardless of whatever myths you may have heard, no matter what old-wives-tales have perpetrated the industry, no matter what your grandfather may have claimed. It's literally making the same claim that "you shouldn't change your engine oil" or "you shouldn't change your differential fluid" etc. It makes absolutely no sense that people still believe this lie.
It's strongly recommended to use the OEM Nissan Matic-J or Matic-S because of the specific friction modifiers. Aftermarket fluids use different friction modifiers which can cause a change in the way the transmission shifts.
Old Mar 7, 2020 | 08:54 PM
andrewl_v35's Avatar
04.5 G35 Sedan 5AT
I have used the Idemitsu Type-J without any issues to date. Seems to perform/shift identically to Matic-J in my experience. I tend to avoid the "one size fits all" fluids, I don't trust them.
Frankie Xenon
Jul 1, 2020 05:59 PM
Albanian122
Accessories
42
Aug 30, 2017 09:50 AM
hurleyguys
Oct 4, 2016 04:59 PM
tjrob2000
Jul 16, 2016 07:31 AM
rrgirgis
Mar 26, 2016 04:06 PM
