AC blows hot air
Old Apr 30, 2016 | 01:04 PM
dlodeuce4's Avatar
AC blows hot air
My 2003 g35 blows hot air. Last night tried to add freon and it wouldn't go in. I tried to add it in the correct line but no luck at all. Does anybody have a clue why? Is this some I could fix myself or should I take it to a mechanic?
Old Apr 30, 2016 | 04:55 PM
telcoman's Avatar
Veteran: Army
Have you followed the troubleshooting steps in the FSM?
http://www.nicoclub.com/FSM/G35/Coupe/2003/atc.pdf
You may not be qualified to do this repair?
ATC Page 11
"CAUTION:
The new and former refrigerant connections use different O-ring configurations. Do not confuse O-
rings since they are not interchangeable. If a wrong O-ring is installed, refrigerant will leak at, or
around, the connection."
Telcoman
Old May 1, 2016 | 03:30 PM
dlodeuce4's Avatar
I tried adding the freon but it's as if it's blowing back in the can. What's a typical cost of taking it to a mechanic
Old May 1, 2016 | 04:28 PM
hurleyguys's Avatar
well if it jsut needs to be charged it shouldnt be too bad. but if it needs to be charged that usually means there is a leak somewhere. to find and fix it will be another story on cost. depends on whats wrong.
Old May 2, 2016 | 10:01 AM
Mustang5L5's Avatar
Unless you hook up pressure gauges and confirm you have a leak, you really shouldn't blindly add a can of R-134a.
And if oyu have a leak, you really need to address that first. Topping off the system is merely kicking the can down the road as what could be a simple O-ring leak now, can turn into a new compressor down the road as moisture leaks into the system and corrodes things inside.
Unfortunately....A/C work is expensive, which is why people just dump a can of R-134a until the A/C kicks the bucket completely.
Old May 2, 2016 | 12:41 PM
dlodeuce4's Avatar
Well I was driving with the AC it magically started working again. I do have a metra kit installed as well. Could that be the culprit?
IL708
Aug 2, 2016 09:40 PM
andrewvk
Interior
Apr 28, 2016 02:30 PM
AKAAG
Apr 7, 2016 07:36 AM
Pumacelled
Apr 6, 2016 11:39 PM
Pumacelled
Apr 2, 2016 10:52 PM
